Results 11 to 20 of 23
Thread: URGENT HELP PLEASE - How to drain reserve tank
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Thanks Avo, I've downloaded and checked. Not much help unfortunately, appreciate if you can ask your mate.
    I'm away all day tomorrow so will look on Saturday.
    Jack
  2. The Following User Says Thank You to jack For This Useful Post:
    Avo (23rd February 2018)
    472 Post(s)
    Just crawled under Mrs MB’s 2001 can’t seem to find any drain bung on the 30L stock sub tank Jack mate, unless under the bash plate hidden away! As AVO kindly mentioned you should be able to transfer pump it mostly out into a jerry/bucket I hope. Our 2001 is located in front of the center cross member behind a steel shield.
    jack (22nd February 2018)
  6. #13
    Ballarat Area
    25 Post(s)
    Thanks MB, I was hoping to get it done today but weather got in the way.
    Never wanted to see this
    Jack
  7. The Following User Says Thank You to jack For This Useful Post:
    MB (23rd February 2018)
  8. #14
    472 Post(s)
    Happens to us all at some stage good mate, better to be safe than sorry, good plan towing I says!
  9. #15
    so if it is in the sub tank.....just use the main and no switch to sub main....whats with the tow truck
  10. #16
    472 Post(s)
    Timeline of the thread and urgent help needed I believe Avo good mate. Trucking is a safe bet to be sure!
  11. The Following 2 Users Say Thank You to MB For This Useful Post:
    Avo (23rd February 2018), jack (23rd February 2018)
  12. #17
    aye.....thank you sir
  13. The Following User Says Thank You to Avo For This Useful Post:
  14. #18
    Ballarat Area
    25 Post(s)
    Avo, apparently every time you start the car it switches fuel from the sub to main tank, unsure how much so didn’t want to take any risks.
    I’ve got RACV totalcare so tow was free, first time I’ve used it in about 20 years, better safe than sorry.
    Jack
  15. #19
    May 2016
    8 Post(s)
    I have had the tanks out there is no drain in them !
    I pulled the fuel sender out . Have a good look for rust in the bottom they have a problem with rust .
    on the bottom . replaced both of mine . With added drains
  16. #20
    Ballarat Area
    25 Post(s)
    Ok all done and easy fix. Found the transfer pump, disconnected the out hose (they are even marked in & out) and ran the pump. Drained the fuel into a container and refilled the reserve tank with diesel. Ran the pump again to drain into main tank, refilled again and drained into main tank.
    Was then confident that if there was any petrol left in there is was well and truly diluted. Car started first kick and ran flawlessly on the drive home.
    Thanks for the input and advice, great forum.
    Jack
  17. The Following 6 Users Say Thank You to jack For This Useful Post:
    4bye4 (23rd February 2018), Avo (23rd February 2018), Cuppa (23rd February 2018), MB (23rd February 2018), Plasnart (23rd February 2018), Woof (23rd February 2018)
