Results 1 to 5 of 5
Thread: patrol y61
    Feb 2018
    Question patrol y61
    Hello everyone .
    I have a nissan patrol y61, 2003
    When I press the accelerator, the orange light on the A / T button is on the middle panel.
    It also seems that the vehicle is not responding well.
    Does anyone have any advice?
    mine does the same.means ya got the power on...mine's a 20120 n a slug,,the 3 ltr wheezer thing...get use to it
    and welcome..
    Feb 2018
    I did not understand you, my friend
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Quote Originally Posted by davidorit View Post
    Not many people do understand AVO let me try and interpret for the sand groper .
    The three litre does suffer from asthma a bit especially when under load so it's not too bad stock tyres and not loaded up but after that performance drops a bit .
    As for the AT light , check the switch is not on the power setting .
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Mine a 08 CRD (manual) and had similar response / pwr problem. IMO, consider getting things happening with a good tune, have your ECU remapped and you will achieve improved performance and be able to run higher max boost up around 20psi (no limp) along with the bonus of running lower EGTs. Check out ECPT Tuggerah.
