Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Throttle pedal free play when using cruise control
    Quote Originally Posted by drgtr View Post
    So would i be correct in assuming its the same for aircon? Depending on how high aircon idle is set. When aircon kicks in its pushing on the throttle cable too hence a bit more freeplay. The higher rhe aircon idle the more freeplay?
    Never Noticed. Makes sense though.
    Jan 2018
    Any chance can you test for me? Please 😁
  4. #13
    Sure. Car is in the panel beaters at the moment was due back yesterday. Will check it out when I get it back unless someone already has.
  5. #14
    Jan 2018
    Thanks mate. All good. Checked today with two other patrols at the dyno place. Exactly what it should do.
    Panel beaters? Hope all is ok?
  6. #15
    no worries,
    Yeah the wife had a run in with a subaru last year. small scratch on the ARB Bullbar and $12k damage to a $13k Subaru. We had to pay the excess so figured we'd get the bullbar painted. They have now had it for 10 days............ We have hire vehicle cover with our insurance so wife is driving a Kluger until it returns.
  7. #16
    175 Post(s)
    Hey mate. Exactly the same on my 2006 4.2 .
    When cruise engaged the vacuum diaphragm under bonnet pulls the lever on the pump and in turn pulls the pedal cable making the pedal seem "Loose".
    It is more or less the same with AC idle as it works on the same principle.
    MudRunnerTD (20th February 2018)
  9. #17
    460 Post(s)
    Nah the air con is controlled via vacuum solenoid found mounted on the firewall and it has two vac hoses running to it. One hose is vac supply and the other goes to the top of the injector pump, and when activated it creates vacuum to the pump, which some how makes elephants turn purple and fly really fast. Lol
    Sorry I got no idea how it actually works on the injector pump. I just know its vacuum controlled.
  10. #18
    175 Post(s)
    As I've been tinkering with my AC last few days ive learnt all about it lol.
    So the AC vacuum controlled diaphram sucks in, pulling a line. This very same line is connected to the same arm as the accelerator arm... Thus increasing the revs.
    SAme goes for the cruise.
    460 Post(s)
    I dont think it pulls a line as such. Its something in that diaphragm that is connect inside the pump to control the revs for this part.
  12. #20
    175 Post(s)
    Yeah sorry youre right. I've mixed it up with the cruise cable, as that works like I explained it.
