Results 1 to 6 of 6
Thread: Leaking Diesel
    Nov 2017
    Victoria
    Leaking Diesel
    Hey Guys,
    I have discovered that my patrol leaks diesel just beside the rear tank on the drivers side. It only leaks for a bit after I take the car for a spin.
    Its a 1994 td42 ,
    Im unsure of what could be causing this or it may be normal?
    Any help is appreciated
    194 Post(s)
    Check your hoses for splits and hose clamps are tight. Check hoses are still connected, such as the vent line from tank to filler.
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    Joey GQ (20th February 2018)
    581 Post(s)
    Hey mate, what's that black cap on the bottom of your rear quarter for?
  6. The Following User Says Thank You to AB For This Useful Post:
    GQtdauto (18th February 2018)
  7. #4
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Was wondering the same thing AB , looks like a gas inlet !
  8. The Following User Says Thank You to GQtdauto For This Useful Post:
    AB (18th February 2018)
  9. #5
    Nov 2017
    Victoria
    Thanks PeeBee
  10. #6
    Nov 2017
    Victoria
    Yeah it used to be Duel Fuel before it was engine swapped
  11. The Following User Says Thank You to Joey GQ For This Useful Post:
    MudRunnerTD (18th February 2018)
