15th February 2018, 04:47 PM
Alternator issue?
Hey guys,
My RB30 Patrol alternator(upgraded one from EF-EL Falcon 110 amp) is putting out 14.2-14.3 max volts regardless of whether it's idling or revving the life out it.
The other day, it had trouble turning over with one of the cranking batteries, so I thought it's the battery and removed it and bench charged while having the engine on the spare battery. With the non-cranking battery, it was showing 14v maximum regardless of the rev range(with that non-cranking battery). And showing 14.2-14.3 fixed voltage with the battery in it now.
It looks like the alternator regulator is putting out a fixed voltage, regardless of idling or revving high.
This can't be a good thing, right?
A dying regulator you reckon?
Thanx in advance for any advice from electrickery experts here.
15th February 2018 04:47 PM
15th February 2018, 05:08 PM
I am he, fear me
No, thats what they are supposed to do, thats why they call them Regulators :-)
The Following 2 Users Say Thank You to the evil twin For This Useful Post:
dom14 (15th February 2018), mudnut (15th February 2018)
15th February 2018, 05:58 PM
How fast did it crank over with the second battery?
15th February 2018, 08:22 PM
mudnut
Slightly faster, but the second battery is a stronger one with higher CCA capacity. The one that didn't crank over was a weaker $100 Autobarn special I bought around three years ago. Only reason it's still alive is 'cos I've been pulse charging it once a month or so.
But, it still passed the load test, so I reckon it's still good. For some reason it wasn't getting charged properly.
FYI, the alternator was always boost around 0.2V or so when I revved it high as far as I can remember, but it's "regulating" it perfectly. I smelled a rat for some reason. Battery ain't that bad. Something else was/is going on. I reckon it's the trailer wiring.
It didn't pop into my stupid head to do the voltage test of the non-cranking battery the moment it was failing to do that. I had the multimeter right next to me, but 'cos I got stuck in a tight spot with the damn trailer at the back, I got panicked.
I'm going through all the trailer wiring both in the vehicle and trailer now. I think the problem is there.
15th February 2018, 08:24 PM
the evil twin
Of course, but I have a clear memory of it's putting slightly more(0.1 to 0.2V) when I was revving high. It ain't doing it now, so I thought the regulator may be playing up a bit.
15th February 2018, 08:32 PM
I am he, fear me
By changing the Battery you changed the load.
The manky battery was dragging down the Alt at idle RPM.
15th February 2018, 08:37 PM
the evil twin
Yeah, you might be right. Another thing is that the highest alternator voltage(both idle and high revs in this case) is 14.1-14.3, depending on when I test it. It never goes upto 14.4 or 14.5 which it used to do.
Either way, if the battery is not the cause, it most certainly contributed to the issue.
I guess it's on it's way out now as a cranking battery, and turning into it's next life as a UPS battery.
