Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Has my battery had the "Richard"
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    Went to start today after about 6 weeks, no sign of life.
    Multi-meter says 2.9V !!!!!
    I think I know the answer, but, you know, someone put me out of my misery.
    Battery is ~4-5 years old.
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Geez that's low and cranks don't like getting that flat , wonder if battery is stuffed and or power is leaking somewhere ?
    Apr 2013
    22 Post(s)
    Thinking of going Optima redtop
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Just make sure your not leaking power first , shame to wreck another battery .
  6. The Following User Says Thank You to GQtdauto For This Useful Post:
    MB (12th February 2018)
    473 Post(s)
    Love Optimas too Ralph mate!
    Reds I’m sure you are aware crank hard and great for winching big motors too. Stick with yellows/blues for now as I believe/experienced they will crank enough for your needs and also handle draining abuse a lot better mate!
    Legendary happygu's Avatar
    Aftermarket batteries are normally only good for a couple of years - not like the standard Nissan Batteries that seem to last and last, but i use the Optima Yellow for my auxilliary and they are pretty good.
  9. The Following User Says Thank You to happygu For This Useful Post:
  10. #7
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    2 volts is not normal for a dead battery. Each cell in your battery produces 2.1 volts so if you had a dead cell you would be down to 10.5 roughly. My guess is you have a serious drain or left something on.
  11. The Following User Says Thank You to Yeti's Beast For This Useful Post:
  12. #8
    473 Post(s)
    Once bought one of those so called ‘regulated’ $30 solar maintenance jobbies for a dam pump. That sure went to shit quick, no chance you had one of them pricks clipped on @poindexter mate?
  13. #9
    Apr 2013
    22 Post(s)
    The Optima web site says Red for cranking, Yellow for deep cycle and Blue for marine.
    I hear what you say regarding the Yellow tops MB, and It's work looking it.
    I have all the "new stuff" wired to the Aux battery (except the winch).
    But the drain issue is going to be looked at.
  14. The Following User Says Thank You to poindexter For This Useful Post:
    MB (13th February 2018)
  15. #10
    473 Post(s)
    Yep, faithful proven yellows in my Trol and a single blue in my Tinny for sounder, lights, bilge pump and elecy trolling motor. According to the blokes at our nearest Battery World only difference with the blue marine is the extra terminals atop. Never looked at the specs for myself though between either colour.
