Results 1 to 4 of 4
Thread: TB45E main fuel tank
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Hi all. My bus is a dual fuel set up and the LPG tank is due for its ten year service and the converter needs to be replaced. Coming in at around the grand mark I thought of ditching the gas and putting a main petrol tank back in. My question is are all main tanks equal?
    Would a tank from a diesel model of the same year '98. be interchangeable with a petrol model? Or would I need to source a tank from my exact model?
    Cheers.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
    330 Post(s)
    Interchangeable from GQ and GU models but no the Utes. Rear 95lt tank is the same across the range and you should get one for free. Sub Tanks are not interchangeable though but any GU wagon will fit a GU wagon.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Chubba (8th February 2018)
    Oct 2013
    Adelaide
    5 Post(s)
    Excellent,. Cheers mate..
    "GO YOU CROWS"
    Patrol Guru Evo's Avatar
    Jun 2013
    Lost somewhere in my own head...
    3 Post(s)
    If you aren't fussed on new, I have seen aftermarket long range tanks going for between $500 - $1000 second hand.
    New, not much more...
    Cheers,
    Evo
