Results 1 to 10 of 13
Thread: 8" car stereo speaker x 4 recommendation
    194 Post(s)
    I upgraded the sound system on the Patrol about 20 yrs ago. At that time i changed the speakers to Kenwood 140W units, 4 ohm. Recently the sound has been cutting in and out so i removed the pass front speaker and the material that bridges between the speaker mounting flange on the door and the cone has disintegrated to basically nothing. i suspect the others are the same. Can i get some recommendations on a suitable replacement. Note, car gets driven 10 times a year, I am not into doof doof stuff and want to stay with the 6" element. The actual sound system is rated at 50w/channel from memory, and is fine, just the speakers are shot. Was going to post a photo but camera battery is flat, can't find charger. Model of speaker is a KFC-1675Mangled speaker.JPG
    Last edited by PeeBee; 4th February 2018 at 07:54 PM. Reason: older than 5YO operator error
    472 Post(s)
    Black Silastic smear rebuild/edges left to dry for 1 week has worked for my AM radio pleasure, NO Bullsh#t mate :-)
    194 Post(s)
    MB nothing left between cone and flange
    MB (4th February 2018)
    472 Post(s)
    Maybe a ‘GLAD’ bake paper ring in first then 1 week smear to set.
    It does work on speakers easily and the like.
    My last century FJ55 2F Petrol Turbo had a Holden Zenith type side flow carby that used to blow the diaphragm once every 28 days :-) Black Silastic for any speakers or low pressure rubbers anyday, only 2 kids for me ;-)
  7. The Following User Says Thank You to MB For This Useful Post:
    PeeBee (4th February 2018)
  8. #5
    194 Post(s)
    Thanks but might wait for a replacement recommendation as I simply can't be stuffed rooting around with anything else on this barge. Buy it, install it, use it, thats my mantra moving forward.. no more invent, reguritate, change, perfect, change, drop a zillion, then go to supercheap and buy the one I should have bought - bit frustrated with the endless air pump - does it show???? Not going to reinvent the car speaker.
  10. #6
    472 Post(s)
    BUMP........for PeeBee please good folks!
  11. #7
    192 Post(s)
    Hey Phil I've got some JBL 6" speakers in the shed that you can have if interested. I'll get some details tomorrow they're 6 inch but pretty deep so might need spacers depending on where they're mounted. JBL make pretty good sounding speakers I reckon.
  12. #8
    194 Post(s)
    Thanks Rossco, looking for as direct a swap as I can get. I think these have simply perished, so maybe the simplest is to buy 4 replacements from autobahn or similar. I was just keen to see if there were any new material developments especially in the cone support area especially for thumping vibration, not at the super frequencies they operate at.
    I guess if all it takes is 4 spacer rings that is fine. Let me know what you have, need to be 4 Pham I believe
  13. #9
    Jbl gto628
  14. The Following User Says Thank You to Clunk For This Useful Post:
    PeeBee (5th February 2018)
  15. #10
    192 Post(s)
    Hey Phil they are JL actually C2-600x, 4ohm. . Just got a pair of them.
  16. The Following User Says Thank You to Rossco For This Useful Post:
