8th February 2018, 10:00 AM
#41
Thanks for the replies guys. I reckon you'd have to go a long way to get better value than that Ryobi brand. I have a plan. I'll buy a trimmer and a blower + 2 batteries for a Christmas present for the garden. Then I can sneak in drills, saws etc etc later on.
The Following User Says Thank You to 10G For This Useful Post:
8th February 2018 10:00 AM
8th February 2018, 10:17 AM
#42
Moderator
MB
Cheers Plassy, I’ve always hand thread started and then run them up lightly but fast. Never in a circle I was tought, always incrementally opposite each shot. Finally torque up same same again. Is this correct, I hope?
The most important part of getting the right torque on your wheel nuts is to Grease your Wheel Studs. If you have never put lube on the wheel studs then friction will give you torque settings that might not be true and could be significantly looser than expected.
I hand thread to a couple of turns then rattle on then Torque wrench to finish. Grease every time the wheel comes off though.
Check out my Toy -->
Rogue Dung Beetle
8th February 2018, 10:56 AM
#43
MudRunnerTD
Oh OK, grease 'em you reckon. It's always been one of those Do I or Don't I things with me. Grease 'em, you can get stuff caught in the grease in the threads, don't grease 'em they can become really crappy to spin the nuts back on by hand.
8th February 2018, 11:18 AM
#44
The 747
10G
I've only just started greasing mine and they are heaps easier to get started. Haven't had any issues with them coming loose after correctly torquing them up which was my concern.
I only use a very light smear of grease on each stud.
8th February 2018, 09:06 PM
#45
Smart like tractor
MudRunnerTD
Why not anti-seize?
96 GQ coil/Cab
08 G6eT
The Following User Says Thank You to Ben-e-boy For This Useful Post:
MudRunnerTD (8th February 2018)
8th February 2018, 10:20 PM
#46
Moderator
Ben-e-boy
Why not anti-seize?
Just what I have handy mate. I find anti seize a little messy too as I have that silver stuff. I will use grease from a tub or spray lithium grease as it's generally handy. It all gets the job done though.
Rogue Dung Beetle
