Results 1 to 4 of 4
Thread: Patrol GR 2003 speedometer bulb
    Jan 2018
    Hello guys,
    I'm new on forum and this is my first post hope is posted corect.
    I have a Patrol GR 3000 from 2003 and almost all bulbs from the speedometer went down. I can't find anywhere this tipe of lamp, and is not a conventional one. Been also at Nissan dealer and they asked for 35 Euro/pc, and they said i need 5 pcs
    Attached some pictures. Does anyone know what's the type of this bulb?
    Thanks a lot!
    @mudnut can you help
    Legendary dom14's Avatar
    38 Post(s)
    Obviously you tested them with a multimeter to sure they are all kaput?
    I wouldn't replace them without finding out the reason they all blew up like that, and
    most certainly definitely won't be paying $50 for a tiny bulb. LED replacement of matching voltage and lux(light intensity) is the
    way I would like to go, but definitely not without finding the reason.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    80 Post(s)
    Separate the bulb from the holder, by grasping the glass and pulling it. That bulb is called a wedge type and is very cheap and common, at least in Australia. Autoparts stores or garages should stock them. Probably only 3 watt for the gauge cluster.
