12th June 2018, 12:20 PM
Hi!
Looks like it is overboost protection is working.
It can be westgate on turbo or this valve
PS. Why does my turbo newer pushes more than 0.45 kg?
I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
12th June 2018 12:20 PM
5th April 2020, 12:25 AM
having same problem on my gu 2.8tdic,when boost picks up good suddenly it drops and a whinding/whisling noise appears !
If someone know what to chack for please let me know !
5th April 2020, 04:20 PM
s wine maker suggests, most likely the poppet valve on the manifold. I took mine off and plugged the hole, didn't affect anything, was a 1997 2.8TD GQ. Facory turbo never pushed mare than 12psi with or without it, just lost the annoying whistle/chatter.
9th April 2020, 04:41 PM
mine is a gu it doesnt have that thing on the manifold
10th April 2020, 08:29 AM
damianovdd
So I now read about a 2t oil in the fuel, and will try it when next filling up the car with fuel.
Be careful doing this as some 2t oils contain zinc which is not good for injector nozzles (eg racing oil) and you may loose more performance.
2008 CRD Auto Wagon
10th April 2020, 08:33 AM
pollenface
Just use the cheaper non synthetic oil and you will be fine. I have done this for years and found the vehicle was a bit quieter in operation, no other positives I can detect - some claim power increases, torque increase, lower soot - have not seen any of these.
