18th January 2018, 01:57 PM
The 747
Home automation comes to the vehicle market
The Following 3 Users Say Thank You to Winnie For This Useful Post:
AB (18th January 2018), Aquarian51 (18th January 2018), NissanGQ4.2 (18th January 2018)
18th January 2018 01:57 PM
18th January 2018, 08:33 PM
SUCH IS LIFE
Arb have their Linx system as well, it would be handy if you have 54 thousand switches on your dash,
................on the move
________________________
______ 2017 D-Max _______
19th January 2018, 09:18 AM
I have recently gone to the dark side & now drive a V6 Amarok, it comes automated, it even turns down the radio when you put in reverse.
I still have my Patrol wagon as the Amarok is work ute.
19th January 2018, 05:46 PM
Rotaredom
GeeYou8
2 me that would be annoying as, why would anyone want their radio turning down every time they put it reverse?
19th January 2018, 07:41 PM
Smart like tractor
Can you actually write some code on these things?
I've wanted to use a little micro plc to control a few things for a while.
96 GQ coil/Cab
08 G6eT
19th January 2018, 07:55 PM
Moderator
If I was starting to set up a new vehicle and could foresee a need for a heap of switches it would be awesome. The ARB one is swishhhoo! But my vehicles are all but done could not justify the conversion.
Check out my Toy -->
Rogue Dung Beetle
19th January 2018, 09:29 PM
Rotaredom
Ben-e-boy
I highly doubt it Benny, I could not see anyone like Redarc or ARB allowing it.
Build your own using Arduino if u want the ability 2 code
20th January 2018, 02:43 PM
#8
Smart like tractor
NissanGQ4.2
I was thinking more industrial for a controller for the stuff I've had in mind for some time now, including security. But if this has huge capabilities I would consider automotive specific controllers.
96 GQ coil/Cab
08 G6eT
20th January 2018, 03:34 PM
#9
The 747
Ben-e-boy
It probably wouldn't be hard to rig something up. My home automation system runs on 12VDC
20th January 2018, 07:58 PM
#10
Smart like tractor
Winnie
Set up isn't the issue, it's the real estate it takes up that is the issue more than anything. I'd probably have to make a new dash to fit it and be accessible to work on
96 GQ coil/Cab
08 G6eT
