9th May 2011, 08:52 AM
Advanced
GQ patrol crunch
G'day all!
Recently hooked up some spotties to my patrol used relay fuse etc etc somehow manage to have a short to earth... (still have'nt located it) drained my battery... jump started her but still took alot for her to crank over and when it did made an awful crunching sound and blew a puff of white/grey smoke... drove it home, cheacked the battery was running 12.9 V so it charged but then went to crank her again and same problem, she took abit to turn then a loud crunching sound... Could this be related to the spotties earthing out? or any suggestion where to start or what it could possibly be?
Cheers guys!
9th May 2011 08:52 AM
9th May 2011, 01:55 PM
could be a number of factors here ,wheres the crunching sound comming from??
9th May 2011, 02:41 PM
Simpson Desert
Starter motor? Is it diesel or petrol?
9th May 2011, 03:32 PM
GUtsy ute
that was my first thought but that would have to be a monster short out
9th May 2011, 03:42 PM
I don't think it is anything you have done while connecting the spot lights, but just incase where did you connect the wires that go to terminals 85 and 86 of the relay?
Also where did you connect the earth from the spot lights.
I would check for dirty/bad connections at the battery terminals, where the main earth connects to the body and block and also the main battery cable at the starter motor.
A good tip for this is after you have tried to start it a couple of time, feel with your hands over the battery terminals and lugs if there is a bad connect it will get real hot real quick.
It sound like the problem is with your starter motor have you driven through any deep water or mud lately?
9th May 2011, 08:51 PM
Really out there, but you don't have any wires or bolts near fan?
Tim
10th May 2011, 07:19 PM
Advanced
Hey guys thanks for the tips, just stripped down the starter motor... shes rooted! bearing sitting behind throw out was completley missing! along with other wear just a coincidence that it happened straight after the spotties i guess... have'nt even priced one up yet what would be better? second hand/new or kit?
Cheers!
10th May 2011, 07:22 PM
Banned
bigboss
Cheers!
At least you found it mate - good work. Can't help on the new v second hand question apart from opinion - I always go new for water pumps, alternators, etc - just to be sure, to be sure!!
10th May 2011, 07:46 PM
10th May 2011, 07:59 PM
RIP - valued member and true gentleman of this forum that will be missed by many!
manual or auto box, and how many have you got to push it if manual :-)
