Results 1 to 10 of 11
Thread: Home automation comes to the vehicle market
    https://www.redarc.com.au/vehicle-ma...t-systems/tvms
  2. The Following 3 Users Say Thank You to Winnie For This Useful Post:
    AB (18th January 2018), Aquarian51 (18th January 2018), NissanGQ4.2 (18th January 2018)
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Arb have their Linx system as well, it would be handy if you have 54 thousand switches on your dash,
    ................on the move
    ________________________
    ______ 2017 D-Max _______
    Dec 2015
    WA
    5 Post(s)
    I have recently gone to the dark side & now drive a V6 Amarok, it comes automated, it even turns down the radio when you put in reverse.
    I still have my Patrol wagon as the Amarok is work ute.
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by GeeYou8 View Post
    2 me that would be annoying as, why would anyone want their radio turning down every time they put it reverse?
    22 Post(s)
    Can you actually write some code on these things?
    I've wanted to use a little micro plc to control a few things for a while.
    96 GQ coil/Cab
    08 G6eT
    330 Post(s)
    If I was starting to set up a new vehicle and could foresee a need for a heap of switches it would be awesome. The ARB one is swishhhoo! But my vehicles are all but done could not justify the conversion.
  9. #7
    Aug 2010
    17 Post(s)
    I highly doubt it Benny, I could not see anyone like Redarc or ARB allowing it.
    Build your own using Arduino if u want the ability 2 code
  10. #8
    22 Post(s)
    I was thinking more industrial for a controller for the stuff I've had in mind for some time now, including security. But if this has huge capabilities I would consider automotive specific controllers.
    96 GQ coil/Cab
    08 G6eT
  11. #9
    It probably wouldn't be hard to rig something up. My home automation system runs on 12VDC
  12. #10
    22 Post(s)
    Set up isn't the issue, it's the real estate it takes up that is the issue more than anything. I'd probably have to make a new dash to fit it and be accessible to work on
    96 GQ coil/Cab
    08 G6eT
