Results 1 to 10 of 17
Thread: Transfer case wind up?
    194 Post(s)
    My GQ patrol is fitted with the TD42 gearbox and the original transfer case from the TD28 engine, and running behind a Chev Diesel V8. On the last two times out with it I have had difficulty getting the transfer case lever to de-select from low range. This is a total pain as typically I need to drive it backwards and forwards then it comes free, however I am unsure if this is the actual solution or coincidental. Of greatest concern is the PTO winch which needs to have the transfer case in neutral before locking in the winch PTO - this is a bit different also as the PTO drives a HYDRAULIC pump off the gearbox; I needed to use the winch this last couple of days after blowing a tyre on a bad section of track and was too steep to crange it in-situ.
    I am wondering what could be causing this? I note the front tyres are more worn than the rears, rears almost brand new, fronts maybe 30,000klm on them, Wrangler MTR, so tread depth would differ by maybe 5-6mm front to rear? I use the diff locks a bit also, so everything gets locked up to speak and can only allow on track slip to stock the wind-up? Has anyone else had this problem and what resolved it? I had the same trouble today just before ending the track, and backed up and forward for maybe 100m, then I did put the gearbox into neutral and foot off the clutch, and transfer lever slipped out without issue - wondering if there is a link between any of this?
    Prob the worst vehicle for windup I drive regularly is the SES 70 series 6 Cyl Land Cruiser Troopies, pretty much get it every time (no lockers fitted).
    Only method without lifting wheels I know to 'clear' the windup is... Wheels straight on any loose surface, select reverse gear, apply a 'gentle' push the the selector, let the clutch out and start reversing and if they don't pop out within 5 metres, select first and repeat.
    Never had to travel 100 metres in anything but we did have a busted arse Rodeo that would sometimes need a couple of attempts
    Transfer windup is a 'front to rear' thing so you can also get rid of it by jacking one side with diff unlocked.
    As for getting stuck and having excessive windup and then needing neutral to run a PTO... well, uuummm,... comes under the 'sux to be you' category I s'pose.
    I don't know of a solution to that situation
    Latest gen electronic stuff is easy, select mode, drive till the light goes out/comes on (the old 'what you don't know won't hurt you' solution).
    Ford Rangers will often take a while to think it thru
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    PeeBee (10th February 2018)
    Expert the godfather's Avatar
    Mar 2011
    Piara Waters, WA
    Well, I am sorry to say this, but there is no fix for this issue that I am aware off. The problem is actually across all breeds. Worst I have encountered was a Pajero, took us an hour to get the dam thing free. Ended up having to jack it up and let them all spin.PTO driven winches are great as far a torque goes, but as you rightly point out, the transfer box needs to be in neutral. This is a problem if you have wind up issues. By the way, the HJ-75 cruisers have this same issue. No easy fix, but if you want to keep using the winch, maybe remove the PTO, pump, and hydraulic motor and replace it with an electric motor. If it is a Thomas or APE winch you can by a 12v motor that will bolt straight on to where the hydraulic motor connects to the winch.
    Side note: Hydraulic pump could be useful for other applications. Maybe hook up a small compressor or some break away couplings to run a jack.
  6. The Following User Says Thank You to the godfather For This Useful Post:
  7. #4
    192 Post(s)
    Try driving a ford ranger with the stupid electronic dial thingies. Had to drive for miles screaming in low range in those stupid things cos they won't disengage Arrgh ! ! Sorry not much help lol . . .
  8. #5
    Mar 2011
    Piara Waters, WA
    Yep, I have one of those for work. Funnily enough though, it doesn't happen when it is fully loaded. Work that one out.
  9. The Following User Says Thank You to the godfather For This Useful Post:
    Rossco (10th February 2018)
  10. #6
    194 Post(s)
    Thanks guys, but what is ROOT cause? Is there anything i can do to reduce this? Is it caused by component wear - transfer case has only done a small number of klm in low range, plus has the Marks 4WD 85% gears for final drive. would say its pretty well new condition. I need to pay more attention to what i specifically do to unlock it also, but 100m total back and forth is about real i think, and that lever is locked solid, then 'something happens', and it just slides out into neutral like silk - unbelievable. I had to move back and forth at least a dozen times when caught on the hill to get it to release, and certainly didn't travel 100m on that occasion - maybe 20m all up, then again, simply released without any real effort, luckily!
  11. #7
    Mar 2011
    Piara Waters, WA
    AS rule the only thing you can do (that I am aware of) is try and keep all your tyres the same, and with even wear. I also avoid being in 4WD unless you need to be. The wheels need slippage to not allow wind up. Hence we never drive on tarmac in 4WD. Other than that, I am interested if there is another fix.
  12. The Following User Says Thank You to the godfather For This Useful Post:
  13. #8
    The ROOT cause is the laws of physics in that the front wheels and the back wheels travel different distances.
    There is no fix which is why every 4WD does it even straight off the showroom floor with now component wear, identical tyres etc etc etc
  14. The Following User Says Thank You to the evil twin For This Useful Post:
    PeeBee (11th February 2018)
  15. #9
    472 Post(s)
    I could imagine Phil mate that blowing a tyre on say Axle Hill if it were wouldn’t be too fun :-( No doubt this 4th blown tyre would have greatly assisted wind up whilst scrabbling to your halt before needing PTO winching. Being that your winch requires neutral to work would undoing your front hubs help take some pressure off the driveline before selecting N and hauling up? Front tailshaft could be removed too I guess in an emergency but would hate to be under there on that hill especially!
    EDIT: Freespool the winch first and connect up ready and also rock chock rear wheels to secure the truck before hubs undone of course.
  16. #10
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    If you are really stuck the easiest way to release wind up is to jack up a wheel. I have had to do this on various vehicles during 4WD trips in the High Country.
  17. The Following User Says Thank You to BillsGU For This Useful Post:
    MB (11th February 2018)
