Results 41 to 43 of 43
Thread: 5th gear went Pop
  1. #41
    109 Post(s)
    I'll check mate. Good advise. I had to remove the engine mounts and drop the engine onto the chassis mounts to do it myself last time I had it out.
    If you're happy with workmanship post up who did it for my memory bank. Used to live in Bendigo and still get up there from time to time
    461 Post(s)
    The good news is if 5th does go, you can always use 4th to get home.
    All up cost me $880 + freight for the box, and $650 in labour. No way was I going to do it at home when thats all the labour costs, gearbox out is a prick.
    You got out of it pretty cheap I reckon. The ratios are different from a ZD to TD box, but I dont know how noticeable it will be. I run a ZD box with the upgraded 5th gear, but the rest of the box has seen better days so I'm just trying to find a good enough excuse to get a rebuilt TD box.
  4. #43
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    So far so good. Took it for a 150km round trip today feels better than the old box through all the gears. There is less movement in the shifter and just feels tighter.
    So far looked at firewall and no evidence of firewall bashing. And everything seems to work well. Havent tried 4wd yet, monday I'll take it for a spin.
    Fluid drive in Kangaroo Flat did the work. Easy to deal with and just around the corner to me.
  5. The Following User Says Thank You to sooty_10 For This Useful Post:
    Plasnart (11th February 2018)
