Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 0707 code
    Oct 2017
    Well a quick update...I've just got home and started the ol girl up moved into a shady spot...still sounds crook😣...ive just disconnected the safari chip and gave that ago. I had fingers crosed but it started the same with no change. My next steps will be 1) drain the tank completely and add new fuel...if that fails then ill will pull the rocker cover off to check injectors....has anyone else had injector failures?
    462 Post(s)
    0707 is Injection pump timing control error. Which could mean the PCB on the IP is faulty. Or even a faulty TPS maybe. Its definitely an electrical issue though.
    Harryz (21st January 2018)
  5. #13
    Oct 2017
    Thanks for the help!...i was starting to lean towards a crook injector due to the horrible top end rattle it gets and the bluesh smoke. I thought Id bumped something when i changed the injector seals out...i was quoted about 300 plus bout 150 to float the ol girl across town just for diagnostics. So in about a week or so I will try and send her out...i think i was hoping for a easy fix i guess😣😣...can they change a PCB out or would i have to change the whole IP?
    thanx again Mudski
    Northern 4X4?...this is a cool store!...if anyones wondering...i have purchased genuine pootrol stuff here great products and great prices!!..saved me a fortune😊
  6. The Following User Says Thank You to Harryz For This Useful Post:
    mudski (22nd January 2018)
  7. #14
    462 Post(s)
    Quote Originally Posted by Harryz View Post
    thanx again Mudski
    Thanks bud... But N4x4 is closing down the OEM side of things and just keeping the Dawes and needle valve kits...
    As for the pump. Do a ring around of some diesel specialists. I believe you can get the pcb replaced? Best to speak to an expert on these I reckon.
  8. #15
    Advanced TrollinAround's Avatar
    Feb 2018
    All the best with this one mate, let us know how you get on.
  9. #16
    @Paul Bow
  10. The Following User Says Thank You to Avo For This Useful Post:
    Plasnart (15th February 2019)
