Results 21 to 30 of 32
Thread: First car GQ Coil Cab
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Slowly gathering bits for the turbo...
    pretty exciting
    Td42 coily
    Plenty of room under that tray for either a water tank or air tank.
    Pretty sure TJM do a slide out shelf for the rear.
    Loving the build keep the Mods coming thinking 3" exhaust
    to unleash some ponies lol
  4. #23
    Oct 2017
    WA
    Yeah definitely a 3" straight thru when the turbo is on.
    I'm probably gonna move the TL tray on and custom build my own one when the cash is available.
    Oct 2017
    WA
    Started the fitting process on Satday
    Had 3 exhaust studs snap on me
    Had to drill them out and retap them after snapping 2 ezy outs.
    Anyway, bring on the turbo...
    Td42 coily
  6. #25
    192 Post(s)
    Far out mate, stuff nightmares are made of, yeah never had much luck with easy outs, think they should rename them lol. Nice one, good luck with the turbo. .
  7. #26
    Oct 2017
    WA
    Fitted the turbo on Satday:
    Ran the oil feed from the hole between the engine mount
    Decided to run the oil drain to a tee in the alt/vac pump drain. I'd heard about the oil backing up story but that highmounts would be fine. In the end I just couldn't be bothered taking the sump off.
    Just need to add an exhaust, and she's finished(well, almost)
    Attachment 77084
    Temporary inlet piping setup:
    Can't wait to get her up and spooling
    Funny thing happened...I decided to start her up and get the oil flowing through..All of a sudden I noticed black and white smoke puffing from the turbo pretty badly. I tried to give her a bit of a rev and she wouldn't rev past 1500, and heaps of black smoke. Suddenly I remembered the rag in the inlet pipe
    Now the piping is installed:
    Took it for a drive without the exhaust...definitely a difference already.
    Noticed the clutch start to lose its feel. I reckon it might have been the hot exhaust heating the clutch lines...what do you think?
    Where did you guys run your PCV breather hose to?
    Td42 coily
  8. #27
    194 Post(s)
    I would change those clamps to HD units as the rubber will get hot and warm and blow them off. Also, make sure the metal joiners have lips so the hose can clamp down on the tube piece. Better still hard pipe it, you won't have a problem then, I have been down this track before and its basically a path to frustration. At least you have a clear mock up for permanent piping though.
  9. #28
    Oct 2017
    WA
    Yeah cheers peebee. I just don't reckon theres a hope.in hell of them coming off..getting em on and adjusted took 2 people using all their might!😀
    Also I'll soon add an intercooler so the piping will be changed anyway.
  10. The Following User Says Thank You to JackoGQYoot For This Useful Post:
    PeeBee (4th December 2018)
  11. #29
    Oct 2017
    WA
    Got a full stainless 3 inch straight thru done at mettams. Damn impressive even with no fuel adjustment
    Runs cooler than before. Now how do you turn the fuel up on a standard pump?
  12. #30
    Oct 2017
    WA
    Dont know of anyone else has tried this?I threw a fibreglass turbo blanket on today and wrapped the dump pipe in exhaust wrap. Made a huge difference in water temp. The underbonnet temps are way cooler now as well. Didnt know it would do so much for me😀. Ill post as ome pics of it tomorow.
  13. The Following 2 Users Say Thank You to JackoGQYoot For This Useful Post:
    AB (29th March 2019), Touses (29th March 2019)
