4th January 2018, 06:56 PM
#11
rusty_nail
could be a possibility, i bought it from atoc(on here) its a genuine temp sender, and all i did was unbolt the old one and plug in the new one.
Only reason I mentioned it was I went through the same thing. Mechanics cracked my factory sender when they were doing other work.
They fitted a new sender, and for the next week or so, every now and then the temp gauge just sky rockets... Long story short. It was a brand new sender that was DOA.
Do you have a infra red thermometer by any chance?? Thats how I ended up finding out my sender was faulty. I was aiming the infra red at the thermostat and whether the temp gauge was on half or all the way up, the temp at the thermostat had not changed a single degree.
The Following User Says Thank You to Hodge For This Useful Post:
rusty_nail (4th January 2018)
4th January 2018 06:56 PM
4th January 2018, 07:19 PM
#12
Administrator
Definitely check the constraints of the fan when hot as above mate, Phill had exactly this issue.
The Following User Says Thank You to AB For This Useful Post:
4th January 2018, 08:27 PM
#13
I am he, fear me
Mightn't hurt to 'burp' the cooling system either in case of an air lock... nose uphill, cap off
5th January 2018, 08:24 PM
#14
Daily Lurker
replaced the radiator today at mudskis direction. his logic was i knew the radiator was blocked at one stage and they never go back to 100%. i drove it round for 20 mins after installing the new rad and it didnt get hot. one thing that has me curious though, i spoke to a few people about the viscous hub today, and asked how it worked. its supposed to get stiff at operating temps? or only when the car is really cooking? after taking the car for the spin this arvo, i turned off the motor and the thing was pretty free, so maybe the motor just hadnt gotten hot enough? either way motor no longer climbing to boil so happy days!
The Following 3 Users Say Thank You to rusty_nail For This Useful Post:
Hodge (5th January 2018), MB (5th January 2018), Rossco (5th January 2018)
6th January 2018, 12:34 AM
#15
Legendary
My understanding of the coupling is when the engine is at operating temperature you should be able to spin the fan 1/4 of a turn with one flick. Of course with the engine OFF.
6th January 2018, 01:40 AM
#16
I am he, fear me
You can't reliably test a viscous fan clutch by spinning the blade assy.
The viscous clutch operation relies on the centrifugal force of the belt driven part of the clutch pumping fluid into the shear plates.
The fluid port is controlled by the bimetallic spring operated valve.
When the driven part is stationary (engine off) there is no centrifugal force to pump the fluid into the shear plates even if the sensing valve is wide open.
Unless the engine is 'overtemp' the valve may only be partially open if at all
https://www.youtube.com/watch?v=UwM4OqsLek4
The Following 5 Users Say Thank You to the evil twin For This Useful Post:
Bidja (7th January 2018), jay see (6th January 2018), MB (6th January 2018), Rossco (7th January 2018), rusty_nail (6th January 2018)
6th January 2018, 09:44 PM
#17
Can you verify its getting hot with one of those thermal heat guns.
next Id run an extra earth strap
6th January 2018, 09:53 PM
#18
TD, whats the extra earth strap for and where would you locate it?
7th January 2018, 08:50 AM
#19
the evil twin
Cheers ET great video to learn properly their workings. I’m unsure of how mechanics properly test them mate if ever we need out there? Just saw this backyard yanky test though that could be a good unsafe method to make confetti or would it be ok if done carefully?
https://youtu.be/w-vI0ByaYP4
7th January 2018, 01:41 PM
#20
I am he, fear me
Hehehe, yeah, that works a treat.
On my CRD I could stop it easily with little effort BUT that proves it is uncoupled not that it works.
The only way to prove it locks when installed is to get the engine hot, really hot.
The clutch isn't very progressive it goes from free to locked over quite a short temp range.
When my CRD was really hot you could tell if the clutch was locked as the fan noise and air blast left you in no doubt.
I wasn't game to try and stop it then.
You gotta remember these suckers work off the air temp flowing over them post Rad.
Hot coolant equals hot air but the clutch has no idea what the engine temp actually is.
My CRD often used to get up around 100 towing in the high 30/low 40's of the WA summer and I don't have any idea what the correlation to engine temp was but if I pulled over the fan would be roaring
If I had to guess I would reckon it was around 95 ish engine temp that the clutch began working but that is a wild ass guess.
It shouldn't work while the engine is 'riding' the thermostat in the low 90's... thats the whole point of decoupling the fan, save the horses and save the fuel.
Mine definitely did not lock up around my normal engine temps of 88 to 92.
I could stop it quite easily at those temps
Anyhow, that was my experiences, can't guarantee they are exactly what should be happening but seems to line up with most things I've read
