Results 1 to 8 of 8
Thread: TD42t to LS1 Conversion
    I'm not sure Chappy's Avatar
    Jul 2014
    11 Post(s)
    G'day guys,
    It's been a while since I've been an active poster on the forums but I'm still an active reader. I thought I'd post up my current conversion to help others in the future looking at doing the same thing.
    After a suspected head gasket/head in my TD & constant driving alongside my brother in his LS GQ I've decided to throw a worked LS1 into my GQ.
    I found a conversion in Brisbane with all the Marks goodies, rebuilt and worked LS1 & strengthened and built 4l60e auto.
    Engine: VY LS1 making 300rwhp on 33s in a GU.
    • Comp Cams cam
    • Precision Roller Rockers
    • Beehive valve springs
    • Aeroflow fuel rails
    • Ported heads
    • Upgraded injectors
    • Genie extractors
    Auto: 4L60e
    • Shift kitted
    • Upgraded bands
    • Pump upgrade
    • Converter shop converter
    • B&M Shifter
    We made a whirlwind 4 day trip to Brisbane and checked out the motor, it was just as described so I took it home with me. Over the last couple of days I've started the swap so I'll post some photos as I go along.
    '96 GQ TD42t
  2. The Following 6 Users Say Thank You to Chappy For This Useful Post:
    AB (30th December 2017), Bacho86 (30th December 2017), jay see (29th December 2017), MB (29th December 2017), MudRunnerTD (16th February 2018), mudski (29th December 2017)
    Jul 2014
    11 Post(s)
    Picking up the motor in Brisbane:
    At home in the garage:
    Pulling the TD out:
    ZD30 transfer cased swapped out for the TD transfer:
    Bolt-ons added to the motor (engine mounts & AC pump added since):
    Clutch pedal removed:
    I ordered a Deatschwerks DW200 fuel pump, the supplier accidentally sent me 2, Merry Christmas!
    I've bent & relocated the metal fuel & brake lines so that they run on top of the chassis rail, & made a sheet metal heat shield which I covered with heat shield material. Apparently it's needed for engineering as the headers run close to the chassis rail.
    Tonight I started cutting out the TD engine mounts. Hit them with the cutting disc, grinding disc then flappy wheel. Chassis will be repainted a nice gloss black.
    '96 GQ TD42t
  5. The Following 6 Users Say Thank You to Chappy For This Useful Post:
    AB (30th December 2017), jay see (30th December 2017), MB (30th December 2017), MudRunnerTD (16th February 2018), PeeBee (30th December 2017), Rossco (30th December 2017)
  6. #3
    192 Post(s)
    Wow, it's turning into more of a mongrel than mine. . . What happened to the td start using water or getting hot? . . Should be able to get a few $$ back for the motor & parts i guess. Good luck work it should be good.
  7. #4
    Jul 2014
    11 Post(s)
    How's yours coming along? It started pushing a bit of coolant into the overflow under high boost. I've bought a new head, waterpump, all gaskets etc so I'll put all that on and sell it as a conversion.
    '96 GQ TD42t
  8. The Following User Says Thank You to Chappy For This Useful Post:
    GQtdauto (16th February 2018)
  9. #5
    192 Post(s)
    Yeah it's going great. About to embark on this turbo install then she'll be done. Well not really guess it's never done there's always something! Considering doing head gasket and possibly head as just want to make make sure it's up to scratch with more power and a bit sceptical on a couple of things. Will have a look tho. . .
  10. #6
    Jul 2014
    11 Post(s)
    Good to hear she's coming along, would surely be the tidiest GQ on the road now. Order your parts from www.partsouq.com it was much, much cheaper than ordering locally.
    '96 GQ TD42t
  11. The Following User Says Thank You to Chappy For This Useful Post:
  12. #7
    Jul 2014
    11 Post(s)
    Removed the second engine mount & reworked my fuel lines and heat shield. I made sure all the fuel lines ran behind the steering column.
    Quick test fit
    Modified the diesel fuel sender to accommodate the electric fuel pump
    '96 GQ TD42t
  13. The Following 4 Users Say Thank You to Chappy For This Useful Post:
    AB (30th December 2017), MB (30th December 2017), Rossco (30th December 2017), Wine_maker (16th February 2018)
  14. #8
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    Looks great mate!
    And it really wants this
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
  15. The Following 2 Users Say Thank You to Wine_maker For This Useful Post:
    BigJ (19th February 2018), MudRunnerTD (16th February 2018)
