Results 1 to 5 of 5
Thread: 2010 Patrol auto - towing
    Sep 2011
    Warnbro WA
    G'day all,
    Can anyone offer any advice regards towing with an auto?
    I'm sure this has been covered many times, but many thanks if anyone has any tips.
    Re: towing - auto - hold/power button/ -O/D - fuel consumption etc.
    Boat/trailer is close to 1.5t, will be towing east from Perth to Melbourne.
    Have done all the obvious work to trainer ready for long tow.
    cheers,
    Mat
    General rule is tow in "power" with "OD" off.
    On long trips where terrain, headwind (lack of as we get some beaut ones over here as you know) and traffic flow permit I will use OD esp across the Nulla obviously.
    "Power" changes the downshift points more than upshift so means less hunting
    "OD" when load is minimal (downhill and or flat, tailwind etc) allows the TC to lock which reduces gearbox temps by heaps
    "Lock" doesn't do bugger all when towing really, unless you wanna drive it like a manual, it is more for snow, slush etc
    Fuel - too hard to call as depends on drag from boat and load in yours, roof load etc
    I'd call it 20% more and work from there.
    Plenty of stops across the guts now but where to do a fuel stop I always use the "next stop +1" rule.
    Allow for enough fuel for next stop +1 in case the next stop has a fuel bowser/stock/genny/etc issue and that way you can get to the next sucker after that and not get stranded
    Your biggest issue may be coolant temps this time of year so make sure the fan clutch etc etc are all tickety boo
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    Bigcol (31st December 2017)
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    A torque lockup mod will help with trannie temps and improve fuel efficiency ,best mod for towing in an auto imo.
  6. The Following User Says Thank You to GQtdauto For This Useful Post:
    the evil twin (28th December 2017)
  7. #4
    Totally agree, dunno if the OP has the time tho... I got the impression he is about to set off real soon.
  8. The Following User Says Thank You to the evil twin For This Useful Post:
    GQtdauto (28th December 2017)
  9. #5
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I was in a similar situation and left with a relay but it was the wrong one and I regretted not finding the time to get it done so two options just the basic one relay and one switch or buy the plug in version from wholesale automatics .
  10. The Following User Says Thank You to GQtdauto For This Useful Post:
