Results 1 to 10 of 10
Thread: GQ Ute fuel tank location
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Hi guys
    Was wondering, My ute has the fuel tank mounted behind the rear axle, in between the chassis rails. Is this where it was mounted from the factory?
    I am starting to want for more departure angle and clearance at the rear. How hard would it be to relocate the tank to behind the cab?
    Td42 coily
  2. The Following User Says Thank You to JackoGQYoot For This Useful Post:
    MB (24th December 2017)
    472 Post(s)
    Merry Christmas Jack mate!
    I’ve run a couple of 99<>01 utes up fairly descent tracks without tank issues to date. Them vintages were well/are tucked up for good angles IMHO :-)
  5. #3
    Oct 2017
    WA
    merry christmas to you too mate
    cheers for the reply though
    Td42 coily
  6. The Following User Says Thank You to JackoGQYoot For This Useful Post:
    MB (26th December 2017)
  7. #4
    472 Post(s)
    Cheers Jack, pic below of my current 1999 ute GU departure angle with stock tank/stock bash plate. I’m guessing one could completely remove this ‘main’ tank if truly needed and plumb all lines/electrics up to the stock 80L ‘sub’ tank under/behind our driving arses. I do personally like having 160L+ for my needs and would honestly only do this for a full comp car I guess.
    You may have a GQ ute too, so please disregard this ramble if so mate :-) ?
    JackoGQYoot (28th December 2017)
  9. #5
    472 Post(s)
    EDIT: I am a dickhead, “GQ” written in your title not post, wanker MB....LOL :-(
    Bigcol (31st December 2017)
  11. #6
    Oct 2017
    WA
    Lol!
    Td42 coily
  12. The Following User Says Thank You to JackoGQYoot For This Useful Post:
    MB (28th December 2017)
  13. #7
    Oct 2017
    WA
    That photo looks almost exactly the same as under the back of my GQ, so they're obviously identical...
    Td42 coily
  14. #8
    472 Post(s)
    Just stopped into my bro’s place and quickly checked out his GQ work ute mate. Does look very similar angle I’d say too at a glance! Forgot that this thing also has a whopping custom say 150L+ sub tank behind the cab up high on the tray underside that might be of interest for you Jack mate.
  15. The Following 2 Users Say Thank You to MB For This Useful Post:
    AB (28th December 2017), JackoGQYoot (28th December 2017)
  16. #9
    472 Post(s)
    FWIW, the tank being so high up under, the filler neck has needed to be squeezed between tray and cab on say a 45 degree flow angle.
  17. The Following User Says Thank You to MB For This Useful Post:
  18. #10
    W.A. (wandering aust)
    Strewth ... 150 litres...now THAT is what I call an Aux Tank.
    Next step up would be a 1,000 litre IBC on the Tray
  19. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Bigcol (31st December 2017), MB (28th December 2017)
