Results 11 to 20 of 27
Thread: Gq patrol anti theft protection any good ideas?
    Legendary dom14's Avatar
    38 Post(s)
    Personally I think these anti theft devices are the best ever made just not sure why they didn't catch on .
    About the fourth clip in .
    https://m.youtube.com/watch?v=l8oPVVGYQ40
    I have a vague memory of mate's girlfriend's dad performing the role of the trunk monkey, long long time ago.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. The Following User Says Thank You to dom14 For This Useful Post:
    GQtdauto (18th December 2017)
    Advanced mad66's Avatar
    Nov 2017
    Victoria
    I am not sure if this is standard but there is a little red led just where the ignition switch is a mate recons it could be aftermarket security. if you turn over the motor straight away it won't start. You need to turn the ignition to on for about 15-20 seconds then turn over and it starts. Not sure if this is to do with the a glow plug timer or not. any ideas.
  5. #13
    38 Post(s)
    Quote Originally Posted by mad66 View Post
    Not sure. Diesel folks here would know how to answer that question better.
    I think the red LED you mentioned above is the glow plug delay indicator rather than an immobilizer.
    There are blinking LEDs that you can wire up with or without a resistor, depending on the LED max reverse voltage. Pretty handy as it fools anybody that there is an alarm system installed in the vehicle when it is not.
    Wire it up with the alternator trigger wire(white with red stripe usually).
    You need at least a 500 ohm resistor(at least 0.5W) along with the standard 2v blinking LED.
    All can be purchased under five bucks from Jcar Electronics or order online from ebay.
    Use the below diagram if you are interested. The diagram is from typical alternator wiring.
    Get at least two LEDs in case one ends up cooked. I think 1k ohm resistance is the safe range, rather than 500 ohm 'cos some LEDs
    can't handle reverse voltage anymore than 1.5v or so.
    Auto electrickery wizards here let me know if I need to correct the values or the diagram.
    Cheetah Outreach
  6. The Following User Says Thank You to dom14 For This Useful Post:
    GQtdauto (19th December 2017)
  7. #14
    Tie a pit bull to the steering wheel, or get a pir light [motion]
    that will come on and hopefully deter the grubs, still go the Pitbull lol
  8. #15
    80 Post(s)
    This'll do it for ya. https://www.youtube.com/watch?v=w39o6eSI06Y
    Most devices fitted are to stop "The Novice Thief." If they really want your vehicle, the professionals will take it regardless.
    I have toughened up the the steering column wiring loom so that it takes a hell of a lot more than a pocket knife and pliers to access the wires.
    It has the draw back of making it harder to work on, but I can live with that.
  9. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (19th December 2017)
  10. #16
    38 Post(s)
    Why not make it super hard by implementing all kinda stealthy electrickery!?!?
    You covered it entirely with epoxy??!!
    Cheetah Outreach
  11. The Following User Says Thank You to dom14 For This Useful Post:
    mudnut (19th December 2017)
  12. #17
    Nov 2017
    Victoria
    pittbull lmao, that would work but might attract some unwanted attention lol. I do have some pir sensors but can be a pain in the ass to set up.
  13. #18
    Nov 2017
    Victoria
    That is it just what I have been looking for. But smoking bodies in the car park might also attract unwanted attention.
  14. #19
    Just read a story of a lady from Glen Iris had her Merc [late model] stolen,
    it turned up in Dubai still with the vic plates on it
  15. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    dom14 (20th December 2017), mudnut (20th December 2017)
  16. #20
    80 Post(s)
    Straight into a container, on a ship and out of the country. This is what we suspect happens to the stolen Patrols, too. At least they arrested someone here for it.
