Results 1 to 6 of 6
Thread: Start Up Problem
    Nov 2017
    Victoria
    Start Up Problem
    Hey Guys!
    I have encountered a problem with my td42. ( b.t.w. I'm only 17 and im still learning how my car works, etc.)
    Soooo...
    When i leave my car sitting overnight and go to star it up the next day, it will crank for about 7 seconds with clouds of white smoke coming out of the exhaust. When i turn the car off and go to start it again within a couple of hours it starts normally. The engine runs smooth after it starts.
    Anyone got any ideas?
    Thanks in advance
    581 Post(s)
    Sounds like fuel pump issues to me Joey.
    Either fuel pump getting tired, leaking, timing out or fuel draining away from pump after time perhaps.
    Glow Plugs... white smoke is unburnt fuel
    Are you letting it glow for an appropriate time before you crank the engine?
    If you are then the Plugs or the Relay are probably shot
    Might be low compression but I'd check the Glow Plugs first
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Had my glow plugs replaced and checked did not stop the white smoke when cold , now that summer is here not so much of
    A problem ,I know my injector pump needs a birthday .
    Nov 2017
    Victoria
    Thanks Guys! Worked it out
    Quote Originally Posted by Joey GQ View Post
    ... and ?
    ... it turned out to be the ?
  8. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    AB (15th December 2017), GQtdauto (15th December 2017)
