Results 1 to 4 of 4
Thread: Retractable Seatbelts
    Oct 2011
    Kilcoy
    Thumbs down Retractable Seatbelts
    Hey Guys,
    giving the GU wagon a really good clean & the the retractable 3rd row seat belt retracted when I decided to undo the lower attach bolt (duhhh). How I now extend the belt as it pulls out about 10mm but the locking mech catches. Help!!!!
    462 Post(s)
    Remove the entire retractor assembly and try that way. Depending on the angle the car is at sometimes the retractors lock up.
    Hold the mechanism at the same orientation as if it was fitted to the vehicle and try it.
    AS mentioned by Mudski...if the mechanism is at an odd angle then the device thinks something is wrong and will lock.
    Oct 2011
    Kilcoy
    Thanks guys - I finally worked it out. As Mudski & the evil twins mentioned, it helps to hold in the correct orientation. What really helped was finding that there is a small ball bearing that actuates the locking pawl & when it moves it locks the pawl. very fine to hold it at the right angle but it does work.
    Cheers,
  6. The Following User Says Thank You to Barra1 For This Useful Post:
    the evil twin (6th December 2017)
