Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: The value of dual fuel filters
    Dec 2017
    NE Melbourne
    They are the Delphi version of the CAV type glass bowl filter, bought online from Ebay/Wagga Tractors. Delphi 296. Depending on where you look they are either 5, 5.5 or 6 to 9 microns!
    The diesel in the glass bowl had a fair bit of fine sediment in it, whereas the diesel I drained from the standard filter was very clean.
    Fitting the primer bulb is probably one of the best mods anyone could make I reckon (IMHO). I also fitted one when I fitted the CAV filter (I copied Macca) & it makes priming SO easy compared to those silly short stroke pumps on top of the standard filter. Would be worthwhile even without the pre-filter. I also found that not all primer bulbs were rated for use with diesel, & shopped around until I got one that was.
    If I was fitting the pre-filter again I'd consider putting it on the passenger side of the motor, even though it would significantly increase hose lengths, only because accessing it where I have it is a bit too squeezy, making the task of replacing the filter element & re-bolting the assembly back together a bit of a juggling act. I suspect that if I ever need to replace a filter element out in the desert it will provided sufficient motivation for me to move it when I get back home.
    Attachment 73913
    Hey Cuppa - hoping you can clear something up for me?? I got myself a 2010 GU CRD on the weekend and looking under the bonnet I spotted one of the priming bulbs pretty much the same as what you have in the photo above and I assumed that it was a second fuel filter but now I'm a bit more confident that's what it is
    I also noticed another can with a plastic cover on it and it looks the same as the one in your photo above that is located at about 45 degrees up and right from the priming bulb - what's that one??
    Expert TheFlyingBadger's Avatar
    Oct 2010
    Perth
    Quote Originally Posted by Big Gags View Post
    On the CRD, that priming bulb is for your standard fuel filter (the TD42 filter housing has a pump on top) - i assume it's between the battery and the firewall (slightly towards the engine-side)?
    Jon
  4. #13
    Oct 2010
    Perth
    Is this the one?
    Jon
