Results 1 to 2 of 2
Thread: Using 5kg-200mm MIG wire in 0.5kg one
    Legendary dom14's Avatar
    38 Post(s)
    Hey Guys,
    I have this Ozito gasless MIG that usually take small 500-700g flux core wire reels.
    I just realized it is possible to fit the bigger 4.5kg-5kg one to it space wise.
    https://www.ebay.com.au/itm/5kg-0-8m...oAAOSwoVNaDlxq
    Only issue that I'm facing atm is that the wire won't quite line up with horzontal feed liner on the machine as in the picture below. Below gumtree machine is the one I have.
    https://www.gumtree.com.au/s-ad/rese...090/1163283423
    or this latest one from Bunnings, which I think pretty much the same unit with a different paint job.
    https://www.bunnings.com.au/ozito-90...elder_p6290148
    Any thoughts, advice on that?
    Bunnings guy said they would work with 'adapter' thing at the back of the fitting where the reel fits(to match the hole size of the larger spool with shaft on the machine), but I still have the above question of the bigger reel not quite lining up with the line feeder.
    Or am I overthinking here, 'cos the wires are mild steel flexible wire and they will find the way to the feeder without any extra tension or bending?
    Thanx
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Beginner Sparky92's Avatar
    Dec 2017
    Adelaide
    the weight difference might cause you issues with the rollers breaking if it can only handle the smaller reels i would ring manufacturer in case its under warranty
    2004 GU3 TD42T
