Results 1 to 10 of 10
Thread: TD42 GU Oil Temp
    Aug 2017
    Lightbulb TD42 GU Oil Temp
    Hey guys just wondering where you guys have put your oil temp senders? 2004 gu td42
    Cheers guys appreciate it !
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    oil pressure
    or
    oil temp............
    Aug 2017
    Oil temp bud
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    I have not seen an Oil Temp gauge on the market for several years
    apart for those who have an Auto, and want the temp of that
    possibly put in a fitting in the sump for the probe to screw into.............
    most opt for an Oil Pressure gauge, which you can fit the probe next to the oil filter,
    but you cannot put a temp probe there, as there is a water jacket that goes around it, and you wont get an accurate oil temp reading
    Aug 2017
    Yeah already tapped my oil pressure in there but need somebody to tell me where they put there oil temp !
    581 Post(s)
    The best spot would be the sump somewhere. There's a thread here about it but I can't find it.
  8. #7
    Aug 2017
    You reckon just tap a thread in the dump somehow ?
  9. #8
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    yep,
    if you can work out a position so that the probe is in the oil (nearer the bottom the better)
    the sump is the only place you will get an accurate reading
  10. #9
    Theres a oil filter sandwich plate available with two ports, fits under a filter, I use one for oil temp, other for oil P
    Temps here are direct out of engine and very hot, regulalrly 100-110 deg C
  11. #10
    Expert TheFlyingBadger's Avatar
    Oct 2010
    Perth
    Quote Originally Posted by jet View Post
    indeedy. I've got one sat on my shelf due to be fitted to the ute. It's got 4 ports from memory. It's a very purty purple colour
    Jon
