Results 31 to 32 of 32
Thread: Master cylinder no fluid
  1. #31
    Did you apply a bit of multi-purpose grease to the push pin and the sliding surface on the dust seal at the master cylinder? There must be air and crud in the slave cylinder for it to be getting stuck. Download the manual and have a look at the clutch section so you can see how it all goes back together
  2. The Following User Says Thank You to mudnut For This Useful Post:
    Bidja (14th December 2017)
    sunshinecoast
    you didn't shake the brake fluid bottle before you topped up the master cyl reserve did you. if you did this can airate the fluid and can take a while to settle and bleed out.
