Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Master cylinder no fluid
    Advanced my93maverick's Avatar
    Oct 2015
    Hey guys iv been trying to bleed my td42 but cannot get fluid to come out the master cylinder as we are bleeding it does this mean time for a new one?
    Sent from my CPH1701 using Tapatalk
    Legendary dom14's Avatar
    38 Post(s)
    Are you saying nothing comes out of the bleed nipple?
    Is it loose enough to get the bleeding brake oil out as you pump?
    What sort of bleeding method are you using? Vacuum pump or bleed bottle while pumping the brake pedal?
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  4. The Following User Says Thank You to dom14 For This Useful Post:
    my93maverick (12th December 2017)
    Oct 2015
    Trying to bleed the line off the clutch master cylinder and cannot get fluid to pump out while some one pumps the clutch
    Oct 2015
    Anyone pls help me
    sunshinecoast
    i know it is a silly question but is there fluid in the resivour. where are you trying to bleed it from, at the master cylinder or the slave cylinder. if the fluid becomes contaminated it can sometimes form a gunk plug at the hole where the fluid goes into the master cylinder, it might pay to clean out the resivour
  8. The Following User Says Thank You to nipagu7 For This Useful Post:
  9. #6
    Oct 2015
    Quote Originally Posted by nipagu7 View Post
    Yeah mate got fluid in the resivour it is very gunky im thinkin from a mix of dot 3 and 4 done it wat would i use to clean it with?
  10. #7
    Dot 3, dot 4 and 5.1 are made with the same base (glycol) and are compatible, but dot 5(silicon) is not.
    You can add a dot 4 to a dot 3 system, and dot 5.1 to a dot 4 system, but never the other way around.
    Is there any rust visible in the system at all?
    I have always used new brake fluid as a cleaner. You might want to buy a cheap syringe to suck the gunk out of the line.
  11. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    Bidja (12th December 2017), my93maverick (12th December 2017)
  12. #8
    sunshinecoast
    yeah, as mudnut says, get a cheap syringe or a piece of clear tube 4mm diameter about 500mm long and suck it out, be careful not to injest it, is nasty stuff. i usually wipe the resivour clean with a lint free cloth before refilling. if the fluid still does not go thru, see if you can pressurise the resivour a little some how. if still no go the master cylinder might need a over haul.
  13. The Following User Says Thank You to nipagu7 For This Useful Post:
  14. #9
    Oct 2015
    Would i be able to use a air gun
  15. #10
    Not advisable . If you don't have a moisture separator or trap after the compressor and if you have an in-line oiler, you will further contaminate the system. Take the bleed nipple out and check its not blocked.
