Results 11 to 20 of 32
Thread: Master cylinder no fluid
    Advanced my93maverick's Avatar
    Oct 2015
    Must be blocked i took the line completely understand off the master cylinder and no fluid comes out when i pump it, if there was a problem with the vacuum setup then would that make the brakes play up aswell given there on the same vacuum line because the brakes are fine?
    Sent from my CPH1701 using Tapatalk
    If it is gunked up that badly, maybe it is time for a new system, or a good one from the wreckers.
  4. #13
    Oct 2015
    If it were the vacuum would my brakes also play up
  5. #14
    Time for some advice from @nissannewby or one of the other TD42 Gurus.
  6. #15
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Quote Originally Posted by my93maverick View Post
    Would be solving your master cyl prob first up.
    As mudnut suggested:
    Anyway remove your master cyl have a good look then decide on replacement.
  7. The Following User Says Thank You to Bidja For This Useful Post:
    my93maverick (12th December 2017)
  8. #16
    Patrol Freak gaddy's Avatar
    redlands
    Remove it from the car , trying not to move the push rod that comes throuh the fire wall , remove the circlip that holds the piston in , take the piston out , chances are its fubar and filings off it are blocking the bleeder , buy new master and slave ( as it will probably poop it self soon ) and a new flex hose ,prime and fill the master on the bench before fitting ,then bleed the system at the slave , and done for the next 10 - 15 years . Did mine last week .
  9. The Following User Says Thank You to gaddy For This Useful Post:
    mudnut (7th December 2017)
  10. #17
    Oct 2015
    So got the master off is the piston ment to be pushed in like this still?
  11. #18
    Oct 2015
    Or wat about this dodgy looking rod that acts like its neck is brocken lol
  12. #19
    Oct 2015
    I pushed the rod back in seems ok now is this normal?
  13. #20
    Jul 2017
    37 Post(s)
    Having no direct experience with your veh so info provided for thought.
    All this brown like gunk in the housing that where you are supporting the push rod, is it moisture ingress mixing with brake fluid? If so, it appears your master cyl piston is gone or maybe it is some old grease / moisture mix . The rod wobbling around is more than likely behaving that way as it provides a means for it to allign for assy and operation.
    Look, it is a bit hard to see bore condition but really it is probaly getting past it so might be easier and cheaper in the long run to buy that new master and slave cyl (trouble free for a while). What ever way you choose flush your lines with new fluid prior to hooking up to slave. Gunk and moisture is more than likely to be in the line.
