Results 31 to 32 of 32
Thread: Master cylinder no fluid
  1. #31
    Advanced my93maverick's Avatar
    Oct 2015
    Quote Originally Posted by gaddy View Post
    Did you prime the master before fitting ? How is the flex hose , does it bulge when the peddle is pushed , did you bleed it at the slave ? Is the slave doing it's thing ? That gunk will be in the whole system .
    Hi gaddy i didnt know how to prime the master first and what flex hose are uou talking about, slave is doing its this just feels weird and doesn't hold when in gear plus only have like 1 inch of clutch
    Sent from my CPH1701 using Tapatalk
    Grumpz mudnut's Avatar
    40 Post(s)
    Did you apply a bit of multi-purpose grease to the push pin and the sliding surface on the dust seal at the master cylinder? There must be air and crud in the slave cylinder for it to be getting stuck. Download the manual and have a look at the clutch section so you can see how it all goes back together
    "I am entitled to my own opinion, but the world seems to have forgotten that." E.W.
  4. The Following User Says Thank You to mudnut For This Useful Post:
    Bidja (14th December 2017)
