24th November 2017, 09:43 PM
Chemiweld
Hi guys i think i am getting exhaust gas build up in my 96 GQ RD28 as it pushes coolant to the over flow bottle.
Coolant does not return to radiator.
I have put new thermostat in new water pump new clutch fan and new radiator it does not over heat at the moment sits about half way on temp gauge or just over half when i am doing about 110km with air con on
i was hoping for some advise on a additive to put in to it to hopefully last me to next years tax time so i can get it fixed properly.
There are a few head gasket and block crack products on the market like Chemiweld that claim to work for leaks but i can not find any info if they fix exhaust gas leaks.
Has anyone had a similar problem or know if there is a product i can try for a temp fix
thanks in advance for any information that may help me
Cheers Geoff
24th November 2017 09:43 PM
25th November 2017, 12:32 AM
Hi Geoff Nulon make a product for this type of thing .It has a money back garante so if it doesn't fix it you take the empty bottle back n they refund your money .
Hope you can fix till next year .
Cheers Craig
26th November 2017, 11:07 AM
It is not a good idea to rely on coolant additive to temporarily fix the problem for that long mate, but it is your vehicle at the end of the day. You can use from more expensive "Steel Seal"(basically sodium silicate, nothing more) to all the other head gasket fix products from auto parts shop. I paid over hundred bucks for Steel Seal years ago not realizing how badly it gummed up the water passages between the head and the block, and FIIK what it has done inside the radiator. These are products meant to get the car going for a little while in an emergency situation, rather than for months. Sure occasionally people do take chances and 'succeed'.
For a turbo diesel engine it is an extra challenge I reckon. Try Chemweld or similar product by all means, but it's better to pull the head out and fix it properly. It can be fixed under 1k with a brand spanking new cylinder head(not a reconditioned one) if you're ok with DIY with a bit of elbow grease.
Reason: spellings & grammar
26th November 2017, 11:09 AM
FNqGu04
Cheers Craig
Money back is ok depending on how much you pay for it. If the head gasket fix product that costs under twenty bucks, the money back guarantee is probably not worth the trip to get the money back.
The Following User Says Thank You to dom14 For This Useful Post:
GQtdauto (26th November 2017)
26th November 2017, 02:15 PM
all of those products are short term band aids , if your getting exhaust into the cooling system then either the gasket has failed or the head is cracked. a bit of goop in the radiator is never going to last against combustion pressure and will ultimately just block up cooling passages and your radiator leading to more expense when you find you need to fix it properly
gone to the dark side 2017 vdj 79 dc
The Following User Says Thank You to billyj For This Useful Post:
dom14 (26th November 2017)
26th November 2017, 11:34 PM
billyj
Mine's still going(the radiator) after putting that heavily overpriced Steal Seal crap(Instead getting a Sodium Silicate bottle for ten bucks from chemist).
I did a high pressure(back pressure) flushing of the radiator on a bench last year though, so that might have put bit more time on
it by flushing out some of the gunk.
