Results 1 to 8 of 8
Thread: Td42 missing after new pump
    May 2011
    Hi all,
    So I fitted brand new genuine zexel injectors and a rebuilt 12mm injector pump.
    Took ages to initially start and noticed it was advanced too far so rotated it back to centre of the slot.
    The car starts now but runs and idles really rough, under revs it misses pretty badly?
    Any thoughts, could it just be timing??
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Quote Originally Posted by baxy View Post
    Hi all,
    Not an expert but sounds that way , did you get all the air out of the lines ?
    Wish you took some pics mate .
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    yeah, sounds like you are 1 tooth out on the timing
    gunna be a bugga, but you will need to take it out again
    Tidy Whitey - 99 GU TD42Ti - Diesel Gas, (GUIV Turbo & Intercooler 8Lb boost), 33" Micky T's Baja MTZ's, Dual Batt's, Cargo Barrier, rear draws, HID Super Oscars, winch, Grinch & witch attached and more goodies to come
    May 2011
    Ok, checked pump and the teeth definitely line up, a z other side of the mark. Turned the pump further towards the drivers side and it idles perfect but breaks up just off idle. Have cracked all injectors and primer pump is solid??
    I'm at a loss and have a trip in 6 days 😩
  6. #5
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Might be a job for a diesel mechanic mate , there is adjustment that's sealed but not 100% sure on what it does .
  7. #6
    581 Post(s)
    Just double checking its lined up like this pic?
  8. #7
    581 Post(s)
    Key pressed in...
    I
  9. #8
    581 Post(s)
    Have you got a timing tool?
    You really need to have the timing spot on otherwise take it to someone.
