Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 101
Thread: MIG with argon
  1. #41
    43 Post(s)
    Last time I tried straight argon with a mate the weld looked darker, even though we could see it getting into the root, the toes looked really cold
    Spot on mate, because the argon doesn't carry the arc well, it's wasted (as per my demo above).
    22 Post(s)
    Yeah I saw that after I posted, i have 2 edits there too that you might have missed.
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    BigRAWesty (23rd November 2017)
  5. #43
    Legendary dom14's Avatar
    38 Post(s)
    In one photo it looks ok but the rest appear to show brass covering the inside of the gas holes , the tip is copper so it's not the tip , did you check the holes Dom or can you take a photo at a better angle of the gas ports .
    @GQtdauto, this are the photos of the MIG tip/tip holder/nozzle holder, close-up.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  6. #44
    43 Post(s)
    Haha.. see how I feel tonight lol. I've got a 44 gallon smoker I need to finish..
    38 Post(s)
    These are the photos of the fitting on the regulator that I had to swap over.
    As you can see the original one(silver one) has no O ring.
    I added pictures of the inside of the gas bottle fitting. It doesn't look like it's damaged.
    Cheetah Outreach
  8. #46
    43 Post(s)
    If you undo that gas defuser (yellow bronze section) you'll find the mig liner (long coil looking thing) runs right up to the base of the conductor tip (Brown bit on the end with the wire coming out), so the gas holes may look blocked, but it's totally normal.
  9. The Following User Says Thank You to BigRAWesty For This Useful Post:
    dom14 (23rd November 2017)
  10. #47
    22 Post(s)
    Well being on the farken forum isn't going to get the smoker done.. chop chop
    96 GQ coil/Cab
    08 G6eT
  11. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  12. #48
    43 Post(s)
    And while were on bottles (which look fine), you only need to crack the bottle open, not 100% like you did in your video.
    When on opening a bottle it's only ever 1/4 turn, 1/2 max if I'm feeling generous or bottle is getting empty..
    The pressure these bottles are under you don't need much..
  13. The Following User Says Thank You to BigRAWesty For This Useful Post:
  14. #49
    43 Post(s)
    It's getting there..
    38 Post(s)
    Mate Ben is right what are you doing way too fast and erratic with the hand piece , try pushing only and slow down .
    Yeah, that is true. But, it won't make any difference even if I move slowly and keep the nozzle touched or almost touched. The welds come out bad regardless.
    Cheetah Outreach
