29th November 2017, 10:24 PM
#101
dom14
Ok, cool. I was using a heavy duty wire brush with an angle grinder. I thought it was removing gal with some elbow grease on it, but i reckon you're right. It can be that easy, 'cos if the gal removes that easy, then that would defeat the purpose, wouldn't it?
Grinding it will be from now on, but that means PITA extra and careful grinding work for me.
I tried using gasless MIG today(with 0.9mm gasless wire and low setting with number 3 wire speed) on under 1mm thick mild steel pipes.
It was way too easy to blow a hole through it. So much so, I would've had better outcome with stick welder with low amp.
But, kept persevering to get it right. It is apparently more difficult to weld thin sheet metal with a gasless MIG than with a gas one,
and particularly my Ozito one, which I think 'cos of the lack of amp/volt control(Only low and high settings). Nothing in between.
The rest has to be controlled with wire speed & heat management/hand control.
I use a flap disk Dom takes bugger all effort and easy as .
The Following User Says Thank You to GQtdauto For This Useful Post:
dom14 (29th November 2017)
29th November 2017 10:24 PM
