Results 1 to 7 of 7
Thread: Knocking when turning right on a bump or accelerating
    Nov 2017
    Just wondering if anyone has had a problem with there patrols making a knock sound when turning right under acceleration or on a bump
    472 Post(s)
    G’day mate, it could be many things and others will know better for sure but one area to possibly check could be a body to chassis mount is stuffed or loose somewhere down your drivers side. I’m imagining acceleration G Force and or hard right turn same could be lifting up around the front and clunking down again maybe. Should be an easy check by sharply heaving/lifting up and down on the guards to isolate roughly the area. Good luck, hope others can suggest possibilities soon too, Cheers!
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    If it does it braking as well check your sway bar links , mine sounds shocking and need to replace it .
    Nov 2017
    Had a look at my body mount and it looks collapsed and old mate before me has put like a 10mm block on all the mounts so guessing he’s tried to mask it up before
  6. #5
    Nov 2017
    And no doesn’t do it when braking and have no sway bars in haha
  7. The Following User Says Thank You to Msmit5 For This Useful Post:
    GQtdauto (23rd November 2017)
  8. #6
    Quote Originally Posted by Msmit5 View Post
    radius arm bushes or panhard bushes mate
  9. #7
    Nov 2017
    I have all new bushes haha I was sorta thinking the mushroom bushes on the radius arm but I’ve replaced them it’s shitting me haha
