22nd November 2017, 12:23 AM
#21
I am he, fear me
JackCollo
It’s not coming out of the radiator cap it comes out of the 2 overflow bottle the one underneath the main one
Yeah, I understand that... but you need to consider the pressure cap is there to increase the boiling point of the coolant.
If the pressure cap is knackered the coolant boils at a lower temp
It is OK while driving as the coolant circulates so is constantly getting colder coolant from the Rad
If the pressure is low then when you stop the coolant now 'trapped' in the engine boils and blows by.
Your symptoms are very indicative of a dodgy cap.
It may turn out to be something else but as prev mentioned do the easy/cheap things first
If it is blocked Rad fins etc then the issue tends to be overheating when under load not after being turned off
The Following User Says Thank You to the evil twin For This Useful Post:
dom14 (22nd November 2017)
22nd November 2017 12:23 AM
