20th November 2017, 12:29 PM
Connecting two trailers together
Hey guys,
I've been wondering whether there is a legal way to connect two small trailers together to tow them
one behind the other.
I'm wondering about the,
1)Technical & safety aspects of doing that without any issues
2)Legal side of it whether it's allowed or not
Basically my idea is to attach a small trailer(lets say 6x4 or 8x5) to the other by
fitting in a tow bar/hitch (typical tow ball coupling or different one) arrangement to the front trailer.
I see the "semi-trailers" on the road have such arrangements, but the tow 'ball'/hitch coupling arrangement they use it
different from standard trailers that we use with our vehicles 'cos those huge massive semi-trailers can be reversed with the same wheel turn as the vehicle, don't they? In other words truckie semi-trailers don't need the 'jack-knife' mucking around we do with our small trailers or typical caravan couplings!
I realize this means fitting a tow bar & hitch to the back of the front or main trailer, but that's ok if it is legally allowed. I also realize this can complicate the reversing process, but that may also be rectified by fitting a different type of coupling, rather than a standard tow ball coupling.
Any thoughts, ideas, opinion and advice would be great.
What I really like to do is what as in below picture semi trailers, but in a very small simpler scale.
20th November 2017 12:29 PM
20th November 2017, 12:38 PM
I am he, fear me
If you are talking a Light Vehicle and standard Pig Trailers... totally illegal in all States and Territories
There was a fatal here about a month or two back from some Moron doing exactly that...
dom14 (20th November 2017)
20th November 2017, 12:53 PM
the evil twin
Yeah, I guess that's what I meant. For example, having a Patrol towing an 8x5 trailer while having another 6x4 trailer attached to the back of the 8x5 trailer. I guess, even if it's legal, then there would be functionally challenging or impossible situation of backing up the whole trailer arrangement, unless rear most trailer coupling is a different one to the standard tow ball, so the rear most trailer moves same path as the front trailer.
I always wondered why we don't see that with light trailers while the massive semi-trailers tow huge ones without any issues on highways and freeways(obviously there are functional difficulty of maneuvering them in smaller roads).
I suspected it has to do with,
1)Special licensing requirements for being able to manoeuvre two trailers combined together like that(the extra training required to be able to skillfully maneuver such multiple trailer arrangements).
2)Special couplings those large semi-trailers use that allow them to manoeuvre the two trailers safely and easily, comparing to the
light vehicle tow ball couplings.
20th November 2017, 01:04 PM
the evil twin
Yes, I remember seeing & hearing about that accident.
There must be a reason why it's allowed with those massive trailers while it's not allowed with small trailers.
I'm interested in whether it's flat out illegal or whether it can be legal with certain safety/technical arrangements as it would be with big semi-trailers.
20th November 2017, 01:46 PM
I found this document regarding standard tow coupling methods in Australia.
https://infrastructure.gov.au/roads/...owCoupling.pdf
20th November 2017, 03:15 PM
20th November 2017, 03:53 PM
I am he, fear me
IIRC VSB6 is still only for a single Trailer combination tho...
Road Trains are a whole separate issue again
20th November 2017, 04:13 PM
the evil twin
Yes.
I'm trying to find out the reasons behind the outright illegality of the two trailer combination.
In ideal situations, if it's good for big semi-trailers, we(I) can argue it should be even better for smaller light weight trailers.
But, I don't see anybody doing that & I'm guessing that 'cos it's illegal.
And I can't stop wondering why it's illegal for light weight while it's legal for heavy weight.
I suspect coupling method is one reason, so assuming if the more advanced coupling method is used, then it should be ok.
Then I suspect there is a licensing requirement as well.
The usual heavy vehicle license need to be extended to include a "semi-trailer"(or road trains) I think.
Any thoughts?!
20th November 2017, 06:25 PM
Hi Dom, I am not sure that people don’t do it cos it’s illegal, more that it’s illegal because the engineering of the tow set up, axel positioning, loading and weight distribution, brakes and lighting are a completely different set up. Add to this the training and skills to control the rig and it is not the thing you want to see a tourist doing. Tow vehicle followed by a caravan then the boat and a couple of quads on a third trailer, no not a good look. It would give the mermaids something to think about though, if it was part of their jurisdiction or not.
The Following User Says Thank You to 4bye4 For This Useful Post:
20th November 2017, 06:38 PM
trailer couplings need to exert some downward force on the towball, if there is no downward force or worse still an upward force you will experience severe trailer sway. if the second trailer exerts downward force on it's towball it might negate the downward force of the first trailers coupling, causing swaying. in both truck pictures you posted all trailers were supported front and rear by wheel sets, simple box trailers only have supporting wheel sets (1 or 2) near the middle, allowing them to pivot, when they pivot the coupling up, things can go pear shaped very quickly.
The Following User Says Thank You to nipagu7 For This Useful Post:
