Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
Thread: Timing cover and backing plate removal
    North brissy
    Just a 41mm socket and big breaker bar yeah?
    I don't have the budget for a $500 harmonic balancer, is there a way I can test it while it's off?
    $75AUD for a harmonic balancer plus shipping out of dubai. Currently 2 in stock.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    dom14 (22nd November 2017)
    Legendary dom14's Avatar
    38 Post(s)
    Why was Winnie thinking it costs $500? Was @Winnie referring to the price of a genuine Nissan one from Nissan dealer?
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  5. #13
    http://patrolapart.com.au/product/ge...and-na-gu-td42
  6. #14
    North brissy
    Ben isnt talking about that bit although that is incredibly dear. You want the dampener that bolts to it which is what I quoted.
  7. #15
    North brissy
    This part is $162aud with 11 in stock plus shipping.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
  9. #16
    80 Post(s)
    Just a quick fix for undoing the bolt. I used an impact socket with a breaker bar and a heavy bit of pipe. I wedged the breaker bar and pipe onto the concrete and briefly turned the ignition key to start. It cracked the bolt. This worked on the RB30, but it is a lot smaller than a TB or TD.
    To torque the bolt on an auto, place an old V belt on the harmonic balancer and twist it real tight with a bit of strong pipe. Slip a longer bit of pipe through and wedge it onto something solid.
    If done right, you should be able to torque the bolt to spec.
  10. The Following User Says Thank You to mudnut For This Useful Post:
  11. #17
    38 Post(s)
    I've been doing the undoing and tightening both by putting it into first gear & combining handbrake or brake(lock the brake pedal using a jack) with it as well.
    Does that stress the gears too much??!!
    I'm thinking, using a rattle gun would also stress the gears(if it's in gears), would it not?
    Last edited by dom14; 22nd November 2017 at 09:48 PM. Reason: grammar and missing words, as usual.
    Cheetah Outreach
  12. #18
    38 Post(s)
    It should come to around $200 with shipping. I think that's a fair price as oppose to over $500 here.
    Something's not right for a complete harmonic balancer to cost over five hundred bucks.
    Cheetah Outreach
  13. #19
    80 Post(s)
    I thinking, using a rattle gun would also stress the gears(if it's in gears), would it not?
    Dunno, and dunno. I would never use a rattle gun on engine parts anyway. Having a manual I just chuck it in gear with the handbrake on and use the ratchet and then the torque wrench.
  14. #20
    38 Post(s)
    Yeah, wouldn't use the rattle gun on it either, but I know mechanics do(or at least some of them do when they can squeeze in a rattle gun in there).
    The reason I asked 'cos I've never used the cranking method to loosen it, and for some reason felt uncomfortable with it, but I do know most guys use that method without any dramas.
    I just felt I'm the only one use the gear lock and breaker bar method to undo it.
    Cheetah Outreach
