Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: Timing cover and backing plate removal
  1. #41
    201 Post(s)
    I'll grab a quick pic tomorrow arvo for you mate.
    The bolts should all be very obvious though.
    MudRunnerTD (3rd December 2017)
    Jun 2018
    hi winnie
    how long did this take
    anything youd recommend when doing this again
    i may be doing this soon
    my engine has me dumbfounded as it has 55mm cranknut,oil drain in sump water lines into turbo from thermo housing but mine has a low engine number td42091600 1999 model
  5. #43
    22 Post(s)
    Quote Originally Posted by jjjag View Post
    hi winnie
    You have an post Aug 95 NA blacktop. From what you describe.
    96 GQ coil/Cab
    08 G6eT
  6. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    Avo (10th November 2018), jjjag (12th November 2018)
  7. #44
    Jun 2018
    thanks benny
    i thought with the factory 1" oil drain, and bigger crank would exclude this being na
  8. #45
    Jun 2018
    finally found that a 55mm crank and block drain will generally mean its a t engine
