Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Body Filler Help!
  1. #21
    Hardcore GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    29 Post(s)
    Sorry mate. It's an arc welder with crappy sticks and in a hurry as well(again ). (excuse excuse)
    MIG welding is bit too much trouble atm with too much wire brushing & no bottle atm.
    I reckon your advice to use TIG later to smooth it out is a good idea, but that means lot of wirebrushing and cleaning as well.
    I'll see how it comes.
    BTW, the metal I used are scrap ones with odd sizes that hangs around the backyard.
    If the welds haven't been painted over yet no need for wire brush just crank the Tig up and away you go , but you need gas for a Tig as well .
    Other option is oxy acetylene if you can borrow or have a set .
  2. The Following User Says Thank You to GQtdauto For This Useful Post:
    dom14 (9th November 2017)
    Dec 2016
    Northeast Victoria
    29 Post(s)
    Sent you a pm Dom .
  5. The Following User Says Thank You to GQtdauto For This Useful Post:
  6. #23
    Legendary dom14's Avatar
    34 Post(s)
    Thanx mate.
    I remember you gave me some good advice regarding TIG last time. I have a DC TIG machine. I'm yet to acquire an AC one(which is a one I want badly for my aluminium projects ). I don't have a bottle yet either, but I've been working on getting a good AC TIG machine first. With the troll giving me craps, things to do with TIG welding got put off. Now I'm getting back to it.
    It's pretty hard to arc weld thin pipes with paint on it without blowing holes on them mate(when I don't have enough experience with that). And it's even harder when I have to weld two different thickness & two different types of steel(one being gal and one being powder coated or rusted. I discovered even the painted/powder coated pieces were gal, so I had to deal with lot of toxic fumes & wear the hanky over my nose ). So, it took me ridiculous amount of time to weld the thing. I purposely put extra weld beads on top of each other to strengthen the seemingly weak beads(of course, that's not good practice )
    I bought a chunk of el cheapo arc sticks(2.5mm 6013) that is not so good even with the inverter welder, but had to use them up.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
