Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Recovery Points - Cutting Chassis
    472 Post(s)
    Correct I believe mate :-) ?
    472 Post(s)
    I believe I’ve also heard of blokes using HT engine valves as Bobcat ramp locator pins, bad idea :-( Personally trialled HT and Mild bolts in lateral force tests on paddock trailer suspension and find HT shears off/snaps every time. We’ll have to get a recommendation off TD as to what bolts best suits his kit/lateral pull design:-)
  4. #13
    109 Post(s)
    HT only for straight pull forces is my understanding. Weak in shear.
  5. #14
    194 Post(s)
    Plassy, generally correct. depends on thread form, actual avail root diameter, and type of load, temperature, environment to name a few. Its a myth that putting high strength bolts , being a higher tensile rating will improve strength of a joint - depends whats physically happening. like what Mark suggests, high tensile bolts are generally harder and more brittle, due to the granular config within the material during manufacture, be it from heat treatment or the manufacturing methods like heat tempering or forging. It is possible to torque up a HT bolt to get a higher joint pressure and this is typically the application. They are less likely to strip the bolt thread than the parent metal, which is a danger and why torque settings are important. Also, the nuts are a matched part of the system and the nuts are slightly softer than the bolt to ensure one part of the system is elastic to a degree to give deformation grip, and also fail if the torque is exceeded, thus protecting at least one side of the system.
    For example most normal assy's of manufacture are configured with grade 4.6 bolts or less as they are more forgiving of overload, more elastic and less prone to break due to their plasticity. Structural is usually defined in the GR8.8 range and are harder, higher tensile load capacity but less elastic due to the grains or plates in the material being longer and also the materials in the bolts add positive attributes but at a cost to other areas - generally you get a slightly higher shear rate from a HT bolt, but nothing like the magnitude of the retained tensile load. Moving higher you hit the 10.9 and 12,8 ranged and then exotic bolt materials and bolt diameters with specifics around thread form heat treatment - we lay people would rarely see these, more a specific application and design related.
    Apologies for the long winded response, you opened a door into a design past and this is what I know about.
  6. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (7th November 2017), MB (7th November 2017), Plasnart (7th November 2017)
  7. #15
    Nov 2017
    Thanks for all the input guys. I saw John's "T" shaped ones but my bullbar has a flange/folded section of metal that runs vertically along the the bullbar mount (left of the mounting holes (yellow arrows) in the picture I posted) so I think that might get in the way. Not sure about grinding a bit out of that in terms of structural rigidity for the bar? I'll try post a photo when I get a chance..
  8. #16
    462 Post(s)
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Iron Man recovery points are the only ones I know of that will fit both sides on early GUs. The one on the passenger side comes with nuts that are welded to wires so they can be fitted from holes to the rear of the chassis and then engage with bolts that fit through one side of the left hand chassis only. No need to muck about with the end of the chassis rails. Talk to your nearest Iron Man rep.
  10. #18
    Nov 2010
    Getting a life...
    38 Post(s)
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  11. The Following User Says Thank You to katwoman For This Useful Post:
    MB (8th November 2017)
