Results 1 to 10 of 10
Thread: GQ won't start
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    GQ won't start
    Hi all,
    Went to start my TD42 Blacktop Gq coil cab this morning, and it just made a clicking noise, but the starter motor obviously engaged every now and then because it turned over intermittently. I did do the glow thing so it's not that. Would any of you have had similar issue or know what could be the cause of this?
    cheers
    Td42 coily
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    What voltage is in the crank ?
    Oct 2017
    WA
    The voltmeter on the dash is saying 7 volts.... When I'm driving it, it sits on around 14 volt, so...
    It has been sitting for bout 2 weeks. could this be the problem? could I be losing battery through the labyrinth of wires the guy before me installed on it?
    Td42 coily
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by JackoGQYoot View Post
    Sitting duck for two weeks shouldn't do that unless the battery is dying it's death, slowly.
    What I would do is to get the battery checked for it's CCA output or do a load test, then get
    the starter motor checked for a dying death as well as the connections that goes to it from the battery.
    Autobarn does a CCA check for nothing, afaik.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Nov 2013
    Gold Coast
    Flat battery?
    Hi all,
    cheers
    Mine does the same from time to time. Some times fires up straight away, sometimes have to turn the key a few times. Thought it was the starter motor initially but someone I know reckons not. More likely worn ignition switch he reckons.
    It's not the battery.... Well not in my case anyway
  8. The Following User Says Thank You to Clunk For This Useful Post:
    dom14 (28th October 2017)
  9. #7
    38 Post(s)
    Yeah, an auto sparky some six years or so ago told me the GQ starter switch can develop ghosts inside it.
    I've never replaced mine, but from time to time, not so frequently, it does spit the dummy.
    I have been blaming my secondhand starter(from a Skyline), but it's possible the starter switch.
    It doesn't bother me atm 'cos it's not a frequent problem. If it craps itself in the middle of nowhere, I know
    enough about the wires that goes into it to hot start the troll.
    Cheetah Outreach
  10. #8
    38 Post(s)
    Quote Originally Posted by Chimo View Post
    Flat battery?
    Probably not. It would either keep clicking or crank slowly over with a weak battery.
    I would say the problem is somewhere else. It's either the starter motor or the electrics related to that.
    Cheetah Outreach
  11. The Following User Says Thank You to dom14 For This Useful Post:
    JackoGQYoot (28th October 2017)
  12. #9
    Oct 2017
    WA
    All good guys turned out all it needed was a littel more juice in the battery and she started first crank!
    Td42 coily
  13. The Following 2 Users Say Thank You to JackoGQYoot For This Useful Post:
    AB (28th October 2017), dom14 (28th October 2017)
  14. #10
    Dec 2016
    Northeast Victoria
    41 Post(s)
    If your showing 7 volts there's no way it's going to start , as mentioned a couple of weeks shouldn't matter you have a short or discharge somewhere .
  15. The Following User Says Thank You to GQtdauto For This Useful Post:
    dom14 (29th October 2017)
