Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Rim Offset - How to measure it and get it right
    324 Post(s)
    I answered this in a thread and thought i would put it here for all to view, hope it helps.
    Firstly this is a Nissan Patrol Forum so note that the standard offset on a Nissan Patrol is +10 or positive 10.
    Your offset choice will determine where the wheel sits in your wheel arch and whether it stick out of your guards at all.
    On a Nissan Patrol it is very common to increase the offset into the Negative to bring the wheels further out to the edge of your wheel arches to give a wider track and stop bigger tyres from scrubbing on the inner guard.
    OK so to get the right measurement you are really going to need a rim off the car or your spare off the door if it is the same. You need to measure the back space of the rim centre to figure out the offset. Offset equals how much the centre of the rim is away from the middle of the rim...
    from the diagram below you can see how important it is to know the exact width of your rim. stop into a tyre joint and they will throw a calliper on it for you if you have time or you can figure that out.
    Once you have the width of the rim then you halve it to determine the centre of the rim. Offset is how far from the centre of the rim is the centre mounting plate.
    OK. You need to lay something across the back side of the rim outer edge of the bead to outer edge of the bead. Then measure the distance from that line to the back of the centre plate of the hub to determine where it is in relation to the rolling rim.
    on an 8 inch rim i think they are 200mm wide (you should measure to make sure as every rim is different). zero offset would measure 100mm. Negative 22 offset (considered Toyota offset by most) would measure 78mm to the back plate. Standard Nissan offset of +10 would measure 110mm to the back plate.
    ^^^^ Now that is a pic of an Alloy Mag wheel. the front of the rim is to the left of the pic and the back is to the right.
    or we can get a little technical
    Measuring Wheel Offset
    To calculate offset you'll need the following measurements:
    Wheel backspace
    Wheel Width
    Wheel Center line (outboard flange to inboard flange measurement / 2)
    Subtract:
    Wheel center line from Wheel backspace to get offset.
    If backspace is less than the wheel centerline the offset is negative
    If backspace is greater than the wheel centerline the offset is positive
    Tip:
    To convert from inches to mm multiply by 25.4
    To convert from mm to inches divide by 25.4
    An that is that.. Hope that helps you.
    Cheers MR
  2. The Following 18 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (4th October 2011), aussiemale (2nd June 2012), Ben-e-boy (4th October 2011), Bigbird91 (23rd January 2015), Evo (11th November 2013), Finly Owner (4th October 2011), Flo-w (10th December 2013), gavinsell (29th April 2012), growler2058 (22nd September 2014), Gun517 (8th August 2016), GUtsy ute (4th October 2011), jabsy (27th April 2017), knightpatrol66 (10th June 2012), Mojo01 (10th May 2012), nowoolies (4th October 2011), Spiv (17th November 2017), XTC (26th October 2011), Yendor (4th October 2011)
    Patrol God nowoolies's Avatar
    Perth
    i get my new tyres this week
    so while the rims are bare im gunna measure them up
    thanks mate the more i read on this forum the more i learn or in most cases get totally confused hahahahahaha...roflmao
    HELL NO !!!!!!
    579 Post(s)
    Great information MR, we'll sticky this one for sure!
  6. The Following 3 Users Say Thank You to AB For This Useful Post:
    89GQ (12th June 2013), flemj (5th January 2012), MudRunnerTD (4th October 2011)
  7. #4
    Aug 2011
    Only if we are talking 8" rims.
    The offset for 6" rims is +30, so when talking offset, it is important to also note the width that it relates to.
    What the difference in offset does for the different rim widths, basically makes the backspace the same (approximately 123mm vs 120mm).
    Very confusing when people talk of Toyota offset and Nissan offset.
    Not quite.
    The rim width is the internal distance between the beads. The nissan 16x8 steel GU rim is 203mm between the beads, and approximately 230 from outside flange to outside flange overall, which is the measurement you need.
    Using these numbers (230mm),
    zero offset is a backspace of 115mm
    -22 offset is a backspace of 93mm
    +10 offset is a backspace of 125mm
    When I measured up some GU 16x8 steel rims, I had a backspace of 123mm which calculated the offset as +8.
    When looking at alloy rims, while the rim width will be the same between the beads(for the same rim width obviously), the flange width tends to be thicker than steel rims, so for the same offset, the measured backspace is larger, or to keep the backspace the same, you have a lower offset.
    Last edited by GeeCee; 6th April 2012 at 03:32 PM. Reason: Additional alloy rim info.
  8. #5
    Nov 2010
    The easiest way to measure the offset without having to even know the rim width is to measure the distance from outside edge to face and from inside edge to face and halve the difference
  9. #6
    Aug 2011
    thanks for the above info MR
    i have a question? i measured my offset this afternoon and i got a measuremnet of 101mm from the bead to the front side of the mounting plate and 95 from the bead to the mounting plate on the back side?? would this mean i have almost a 0 offset??
    my next question? would this be an ok offset to run a 33 12.5 tyre oh and its a 15x8 rim.
    thanks
    Gav
  10. #7
    324 Post(s)
    Quote Originally Posted by gavinsell View Post
    thanks
    Gav
    You need to measure through the centre hole to the back mounting face for the front offset to be accurate. The thickness of the centre plate must be measured as part of the front measurement. Measure again. You have the back side so you should be able to get the front with the wheel on the car if you have put it on already.
  11. #8
    Aug 2011
    make that 107...
    Thanks MR
  12. #9
    Napier, NZ
    Thanks MR,
    Whoever disagrees with the saying "Might is right" obviously doesn't own a MQ
  13. #10
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Red face
    Thanks M/R for the great info.
    I was wondering if the offset is also stamped into the back of the alloy rim.
    I have performance alloy rims (Storm 17x8s) that have stamped (next to the size) ET 0.
    Now, I was told that these rims were neg13 offset when I purchased them, but according to the original supplier/importer they only supplied them in a zero offset.
    I haven't measured them as per your first post yet (yes, I am lazy ) as usual I am trying the easy way first.
    Cheers Rodney
