Hey guys just did a service on my ute yesterday and was shocked too see what came out of my fuel filter. I had drained my tanks about a month ago and only water came out so i was shocked to see how bad the fuel filter was. I change it every 10,000. Just wondering of what other things I could do to prevent this or just put in a secondary fuel filter if so just wondering on some steps to do this as I have never done before
I suspect its simply years of accumulation, I had a similar outcome recently and found the main tank breather was all clagged up and constantly open, and being behind the rear wheel its a dust bowl at times. I change filters every 5000 and since your filter was clogged up at least shows its working. I tried a second filter in-line but found the electric booster pump would not draw thru it - pressure drop too great. If you let us know specifically what year/model you have perhaps someone else with a similar issue can respond.
No . I think you need to wait and see what the 4.2 gurus come back with. Mine is a Chev Diesel with an electricbooster and it does not like any upstream filters - found out after I installed one and it stopped on me!!
If that amount of contamination was after 10,000 K's the you either got a bad load of fuel somewhere in that period or, as Pee Bee said, there is a breather problem/bad filler cap or some such.
Whereabouts does your truck spend most of its time? City or Country? Done any water crossings, really dusty gravel or whatever in the last 10,000 K's?
I live central qld but last time the car was off road was about 2 months ago and that was just a 100km dirt road no water crossings. my neighbour gets diesel at same servo as me and he hasn't said anything about his filter. Starting to think maybe I should drop my tanks and have a look?
