Results 1 to 4 of 4
Thread: Poor GQ 4.2 manual shifting
    Oct 2011
    Hi All
    I'm having issues with shift quality in my GQ 4.2 5 speed. It's a real effort to get 1st or 2nd without grinding. Any tips that might help improve or eliminate it. Gearbox onl has 220k on it.
    I suspect a clutch adjust may help, but I'm also concerend it's ready to be replaced.
    cheers
    Damo
    Aug 2014
    Perth
    10 Post(s)
    the 5spd gearboxes in patrols can be quite notchy when cold as in it takes a bit to get it into gear but shouldn't be grinding gears like you say. Once they warm up gear shifts are smooth.
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    drop the oil and try a GL4 grade oil.
  5. The Following User Says Thank You to garett For This Useful Post:
    PeeBee (8th October 2017)
    Expert 92GQ's Avatar
    Sep 2013
    Qld
    X2
    The 4.2's defiantly need a gl-4 oil in their manual transmissions!
    I've been using penrite 75-85 full synthetic for years, makes it a pleasure to drive and my GQ has just gone over 400,000kms.
    The gl-4 oil helps the synchros. Gl-5 oils make the transmission very difficult to shift between gears.
    1992 TD42 GQ Patrol Wagon
    My GQ Build Page
