Results 1 to 10 of 14
Thread: Voltage/current drop using alligator clips
    581 Post(s)
    If you had a 12v device that came with an Anderson plug and you ran this device with an Anderson plug to alligator clip adapter to jumper leads 2m long to battery so clip to clip to a deep cycle battery would you get much of a voltage/current drop or is there just too many other variables to consider?
    Aside from being a dodgy set up, lets pretend that each clip was clean and connected as best as possible, battery in great condition, etc as a general rule would you lose much current with that set up as opposed to a straight Anderson plug to battery source?
    What is the device? For static use, like when your car is parked at camp it should be fine mate. Obviously not a good idea when you are driving.
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    IS this another 1 of your quick fixes ?
    to many variables here
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    A lot of air compressors have long leads and alligator clips , anything I get now is converted to Anderson plug but depending on wire thickness and length of run there will be some voltage drop .
    She'll be right. What could go wrong? Just use a bit of tape on the clips and leads so they don't short out.
    581 Post(s)
    Yep for static use only thanks Winnie. I know it will be fine was just curious of how much drop could you get with a set up like that, that's all.
    Aug 2014
    Perth
    10 Post(s)
    Only one way to know for sure, set it up and get your multimeter and measure at all joins/connections to see
  9. The Following User Says Thank You to gubigfish For This Useful Post:
    AB (5th October 2017)
  10. #8
    Quote Originally Posted by gubigfish View Post
    Wot 'e said ^^^
    If all the connections are OK and the wire of the Anderson to Clip Adapter is of suitable gauge for the load I would expect less than 0.1 volt drop and negligible change to current flow at the connectors.
    Replacing the battery clips with ring terminals or whatever to "permanently" connect the adapter to the Battery will have pretty much the same issues anyway.
    Quick check of voltage with whatever it is you have connected running so the wiring is under load will soon tell you.
    If the Bat +ve / Bat -ve voltage is the same or within 0.1 volt of the plug voltage at the pins of the last Anderson or the appliance plug (whichever you can get at from the back the easiest) then all is tickety boo.
    If it is slightly worse than 0.1, say 0.2 or maybe even 0.3 lower at the appliance plug that will prob be OK if the load is pulling a fair few amps.
    More than 0.2 volts drop under load solely across the 2 metre adapter and andersons would be an issue I would want to fix if it was mine
  11. The Following User Says Thank You to the evil twin For This Useful Post:
  12. #9
    581 Post(s)
    Thanks guys the load on start up is 10amp for 30 secs then back to 1 or 2. I'll check it out!
  13. #10
    Feb 2012
    Camden, NSW
    Voltage drop is dependant on 2 things. The resistance of the circuit and the current you are drawing. If the 10 amp startup has a 1 volt drop, then the 1 amp load will only have 0.1 volt drop
  14. The Following 2 Users Say Thank You to Turtle_au For This Useful Post:
    AB (6th October 2017), the evil twin (6th October 2017)
