Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Very ordinary Brakes?
    Feb 2017
    Hey guys thanks for your help in advance. I have a 1993 TB42E auto 4.6diffs with 35s patrol wagon with twin piston front callipers, the problem I have is holding the brake pedal down hard stationary in low range 1st gear just above idle it drives off brakes won’t hold it, going rock crawling down a hill at idle I have to keep knocking it into neutral they just won’t hold. Braking on road normal driving isn’t too bad considering tyre size etc. I have rebuilt all the callipers machines rotors and new softer compound pads and replaced the vacuum lines adding a small tank inline for vaccum reserve. Really annoying me any suggestions would be appreciated.
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    If you've rebuilt the brakes have you replaced the brake lines to the calipers with an inferior line that's expanding under pressure ? Have heard of this happening once .
    My 94 is pretty much stock as far as brakes go and with 33s on I was able to pull up from about 90 to a dead stop when a car decided to do a u turn unexpectedly in fairly short order .
    Feb 2017
    Thanks I’ll replace them over the next week and see if it helps. 👍
    Legendary
    194 Post(s)
    I upgraded my nissan rubber hoses all round to the teflon/ss braid ones and made a massive difference. Then later changed the pads to the softer ones - better again. I only have single piston calipers also.
  6. #5
    The master farter
    mudski's Avatar
    461 Post(s)
    Yeah steel braided hoses make a big difference.
  7. #6
    Feb 2017
    What did you pay for the Teflon lines and where from? Did you do the long diff to chassis and short calliper to diff?
  8. #7
    Legendary
    194 Post(s)
    I contacted Safebrake, one of the vendor sponsors on the forum. It's been a while but they supplied all hoses to swap over so possibly 6 in total. No idea of the cost, but the service was great and swift delivery. Had a workshop swap them over and again from memory it cost 2 hrs labour plus brake fluid. PM Safebrake and get a quote.
    I have a 3" lift and they handled that with ease.
  9. The Following User Says Thank You to PeeBee For This Useful Post:
    Hodge (3rd October 2017)
  10. #8
    Feb 2017
    I’ve got my hands on a GU booster and master going to give that a go before the ss line I’ll let you know if it’s any better.
  11. #9
    The master farter
    mudski's Avatar
    461 Post(s)
    Quote Originally Posted by Lucas Bree View Post
    From memory it was around the $400 mark for all hoses. Four wheels and the two chassis to diff hoses. No point in just doing some of them. Marks Adaptors I got them from I think. Twas a while ago.
  12. #10
    175 Post(s)
    So, just by upgrading to these Teflon braids , it will improve braking ?
    Brakes are done my next service . Pads , fluid and thinking of getting these upgrades.
    Sent from S6 using TapaPro v.3.73
