Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Gu sliders project
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    Gu sliders project
    I've been following Deadly GU's build thread and thought id have a shot at a set of sliders since my last outing punched the side step into the bottom of the front door.
    Sent a pm to Deadly GU for a few steel sizes and off I went.
    Consists of 32NB med pipe, 50x50x3 shs and 50x10 flat for the brackets.
    I don't have a bender so i used 32NB 90deg elbows instead. I wanted 45deg elbows but they weren't in stock in that size so i had to make do.
    I'll stab away each arvo and hopefully have them on soon.
  2. The Following 5 Users Say Thank You to mjr350 For This Useful Post:
    Avo (5th April 2015), jff45 (20th March 2015), katwoman (19th March 2015), MudRunnerTD (7th August 2017), threedogs (20th March 2015)
    Feb 2011
    Shed
    45 Post(s)
    Cool
    Plenty of pics please I need to do the same
    Sep 2014
    Port Macquarie
    I'll try to take pics as I go.
    Sep 2014
    Port Macquarie
    It's too hot here to do too much today but at least got the rails welded to the square section. You can't see it from this angle but they are welded on at a slight upwards angle.
    I need to put the two little braces in and then I'll start on the mounts.
    Advanced morton2478's Avatar
    Mar 2015
    Lookin good cant wait to see the finished product
    looking very neat I take it the 50 x 50 is the slider component of it
    to protect the patrol sills, I likey a lot lol
    Sep 2014
    Port Macquarie
    Yea the 50x50 will sit directly under the sill its self and the pipe section will act to protect the panel under the doors (which is still probably classed as the sill). I didn't make them massive like some guys do so they won't be much of a side step compared to some.
  10. #8
    been saying for a while most just have pipe steps on an angle ala Cheesy style
    what you have are actual sliders good design nice and strong too.
  11. #9
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    In you're first pic you're showing 6 short lengths of steam pipe. I assumed these were to be notched and welded between the SHS and the external steam pipe but that doesn't seem to be the case because you've welded the ends already.
    John
  12. #10
    Sep 2014
    Port Macquarie
    No the long pieces are to go from the 50x50 to the chassis brackets with a few support gussets later. I have shorter pieces that I have cut at 15 deg to go in between. It was painful to fit the small bits but it worked out well.
    Im noting all measurements down because im going to replicate for a mate later on. Every piece of steel except for the 50x50 has been cut longer so i have room to play. More expensive in the long run but think of it as a prototype.
    I recommend anyone with a little welding experience to jump in and diy your patrol.
